I have a Juniper EX2300 with SNMP enabled. I have added it to LibreNMS
All seems to work…expect in LibreNMS is reports that certain interfaces are blocking when they are in fact forwarding and vise versa
I think I know why LibreNMS is returning the incorrect forwarding or blocking state–the OID dot1dStpPort doesn’t return an ifIndex value. Instead it returns a Port ID. LibreNMS is assuming that it was returning an ifIndex and not a Port ID.
With that said, there is a rosetta stone OID that, I believe, LibreNMS should be using to translate the Port ID into a ifIndex using the dot1dBasePortIfIndex OID so that it can associate the Port ID with the proper interface.
I hope that makes sense. If not, please ask me more questions.
Thanks for everyone’s help.
Thanks,
Zach
