It seems #2066 is not fixed. We’re experiencing a similar problem : the average traffic is completely different than the average measured.
In the screenshot below it is obvious that the sum of the average in+out is 1.80 + 2.11 = 3.91kbps but in the usage it is listed as 31.20kbps, almost 10 times as high.
This happens on all our devices.
Billing was not set up to ‘CDR 95th’ but to ‘Quota’, s 95th percentile shouldn’t have anything to do with this ?
In any case it doesn’t make sense. This is the billing graph for 1 month (which is less than a month, since it was set up recently) :
Well. Usage are both: transferred data (95th percentile)
In my case I use it to “control” what one of our transit bills to us. They use cacti to monitor this.
I was going to say that theirs match with ours but it only does in percentile. In transferred data LibreNMS shows like 70TB more than our transit provider graph…
773.510TB LibreNMS VS. 702.8TB Cacti <-- Transferred Data
3.780 LibreNMS VS 3.754 Cacti <-- 95th Percentile
So yes, something is wrong here.
PS: Also noticed that Percentile is not doing inbound+outbound, only inbound.
Sorry, I don’t know if I was miss-understood. I don’t know anything about billing, I can’t help you. I was just trying to guide you in the right direction. Probably next you need to inspect the billing and see what it is actually measuring and how it calculates it.
