Hi Librenms
DNS request return codes for Infoblox have stop working after the update Sunday
Anybody knows what to do?
- The output of
./validate.php
Component |
Version |
LibreNMS |
1.46-79-g272e51196 |
DB Schema |
274 |
PHP |
7.0.33-1+ubuntu18.04.1+deb.sury.org+1 |
MySQL |
10.1.34-MariaDB-0ubuntu0.18.04.1 |
RRDTool |
1.7.0 |
SNMP |
NET-SNMP 5.7.3 |
[OK] Composer Version: 1.8.0
Are you sure was “update” that stopped this if so what update? What have you done in terms of troubleshooting?
Also, what are DNS request return codes?
It stop working after the update 16 Dec
FTBZ
#5
This is specific graphs and I confirm that no longer working. I will take a look, lot of Unknown Object Identifier when polling.
Seems to have been broken by a security update.
It is working
thanks for your help everyone
Now the DNS work but now DHCP messages is not working
Oopsie, missed a space
You should test the PR next time
I tested, but I missed that.
IT is working
thanks again
