LibreNMS MySQL application works perfect. Nevertheless, as I need to monitor more services that LibreNMS applications do not cover, I’d like to try the Nagios Plugin on mysql to test LibreNMS service monitoring on remote servers.
"These services are tied into an existing device so you need at least one device that supports SNMP to be able to add it to LibreNMS"
Q1: may I add services to a device that does not support SNMP but is ICMP only?
"Firstly, install Nagios plugins…"
Q2: where Nagios plugins to install and the following setup steps to be done, on LIbreNMS server to monitor mysql on a remote server or remote server offering mysql service? Any help would be greatly appreciated.
This is a test for LibreNMS and Nagios plugins integration.
The credentials are for the MySQL DB on a remote server (server name: report, IP: 172.16.9.76), this configuration snapshot is from the dashboard of the LibreNMS server.
