I try is can access SQL server and SQL service is run normal.
mysql -u librenms -p -h 127.0.0.1
[email protected]:~$ mysql -u librenms -p -h 127.0.0.1
Enter password:
Welcome to the MariaDB monitor. Commands end with ; or \g.
Your MariaDB connection id is 55182
Server version: 10.3.32-MariaDB-0ubuntu0.20.04.1 Ubuntu 20.04
Copyright (c) 2000, 2018, Oracle, MariaDB Corporation Ab and others.
Type ‘help;’ or ‘\h’ for help. Type ‘\c’ to clear the current input statement.
MariaDB [(none)]>
[email protected]:~$ sudo systemctl status mariadb
[sudo] password for hkykl:
● mariadb.service - MariaDB 10.3.32 database server
Loaded: loaded (/lib/systemd/system/mariadb.service; enabled; vendor preset: enabled)
Active: active (running) since Wed 2021-12-22 14:45:51 HKT; 23h ago
Docs: man:mysqld(8)
https://mariadb.com/kb/en/library/systemd/
Process: 6254 ExecStartPre=/usr/bin/install -m 755 -o mysql -g root -d /var/run/mysqld (code=exited, status=0/SUCCESS)
Process: 6266 ExecStartPre=/bin/sh -c systemctl unset-environment _WSREP_START_POSITION (code=exited, status=0/SUCCESS)
Process: 6271 ExecStartPre=/bin/sh -c [ ! -e /usr/bin/galera_recovery ] && VAR= || VAR=cd /usr/bin/..; /usr/bin/galera_recovery
; [ $? -eq 0 ] && systemctl set-environment _WSREP_START_POSITION=$VAR || exit 1 (code=exited, status=0/SUCCESS)
Process: 6356 ExecStartPost=/bin/sh -c systemctl unset-environment _WSREP_START_POSITION (code=exited, status=0/SUCCESS)
Process: 6358 ExecStartPost=/etc/mysql/debian-start (code=exited, status=0/SUCCESS)
Main PID: 6325 (mysqld)
Status: “Taking your SQL requests now…”
Tasks: 35 (limit: 2202)
Memory: 88.5M
CGroup: /system.slice/mariadb.service
└─6325 /usr/sbin/mysqld
Dec 22 14:45:50 l1 systemd[1]: Stopped MariaDB 10.3.32 database server.
Dec 22 14:45:50 l1 systemd[1]: Starting MariaDB 10.3.32 database server…
Dec 22 14:45:51 l1 mysqld[6325]: 2021-12-22 14:45:51 0 [Note] /usr/sbin/mysqld (mysqld 10.3.32-MariaDB>
Dec 22 14:45:51 l1 systemd[1]: Started MariaDB 10.3.32 database server.
Dec 22 14:45:51 l1 /etc/mysql/debian-start[6360]: Upgrading MySQL tables if necessary.
Dec 22 14:45:51 l1 /etc/mysql/debian-start[6363]: Looking for ‘mysql’ as: /usr/bin/mysql
Dec 22 14:45:51 l1 /etc/mysql/debian-start[6363]: Looking for ‘mysqlcheck’ as: /usr/bin/mysqlcheck
Dec 22 14:45:51 l1 /etc/mysql/debian-start[6363]: This installation of MySQL is already upgraded to 10.3.32-MariaDB, use --force if you still need to run mysql_upgrade
Dec 22 14:45:51 l1 /etc/mysql/debian-start[6371]: Checking for insecure root accounts.
Dec 22 14:45:51 l1 /etc/mysql/debian-start[6375]: Triggering myisam-recover for all MyISAM tables and aria-recover for all Aria tables
