Since the RPM forge does not is available, in order to install a rrdtools versión > 1.3 in Centos 6, i propose a modification of the instructions from the documentation site:
http://docs.librenms.org/Extensions/RRDCached/
Install default package from Centos Repo:
yum install perl-rrdtool
Download from RPMFind (64bit):
wget ftp://rpmfind.net/linux/dag/redhat/el6/en/x86_64/extras/RPMS/perl-rrdtool-1.4.7-1.el6.rfx.x86_64.rpm
wget ftp://rpmfind.net/linux/dag/redhat/el6/en/x86_64/extras/RPMS/rrdtool-1.4.7-1.el6.rfx.x86_64.rpm
Download from RPMFind (32bit):
wget ftp://rpmfind.net/linux/dag/redhat/el6/en/i386/extras/RPMS/perl-rrdtool-1.4.7-1.el6.rfx.i686.rpm
wget ftp://rpmfind.net/linux/dag/redhat/el6/en/i386/extras/RPMS/rrdtool-1.4.7-1.el6.rfx.i686.rpm
Install dependencies for the downloaded packages:
yum install perl-Time-HiRes gettext xorg-x11-fonts-Type1
Update the packages in your system, at the same time:
rpm -Uvh perl-rrdtool-1.4.7-1.el6.rfx.x86_64.rpm rrdtool-1.4.7-1.el6.rfx.x86_64.rpm
Then, follow the configuration instrucctions for configurate rrdcached in LibreNMS:
vi /etc/sysconfig/rrdcached
# Settings for rrdcached
OPTIONS="-w 1800 -z 1800 -f 3600 -s librenms -U librenms -G librenms -B -R -j /var/tmp -l unix:/var/run/rrdcached/rrdcached.sock -t 4 -F -b /opt/librenms/rrd/"
RRDC_USER=librenms
Then create and set permission in ths folders:
mkdir /var/run/rrdcached
chown librenms:librenms /var/run/rrdcached/
chown librenms:librenms /var/rrdtool/
chown librenms:librenms /var/rrdtool/rrdcached/
chkconfig rrdcached on
service rrdcached start
Edit /opt/librenms/config.php to include:
$config['rrdcached'] = "unix:/var/run/rrdcached/rrdcached.sock";
