Hi all
I’m trying to setup the product since yesterday.
Yesterday, using the old setup instructions still based on php7.4,
I was able to reach the web GUI showing the pre-check page,
where a message inform about the necessity to use php8.1 version.
Today I repeated the procedure, which is updated including the php8.1.
The ngingx and fpm services are starting (apparently) properly,
but I can’t gain the access to the web GUI to complete the installation.
The following error banner appeared.
Here below some logs.
Could someone help me please ?
Thanks in advance
I.
root@librenms:/opt/librenms#
root@librenms:/opt/librenms# service nginx status
● nginx.service - A high performance web server and a reverse proxy server
Loaded: loaded (/lib/systemd/system/nginx.service; enabled; vendor preset: enabled)
Active: active (running) since Fri 2022-08-05 15:08:53 CEST; 39min ago
Docs: man:nginx(8)
Process: 564 ExecStartPre=/usr/sbin/nginx -t -q -g daemon on; master_process on; (code=exited, status=0/SUCCESS)
Process: 711 ExecStart=/usr/sbin/nginx -g daemon on; master_process on; (code=exited, status=0/SUCCESS)
Process: 4033 ExecReload=/usr/sbin/nginx -g daemon on; master_process on; -s reload (code=exited, status=0/SUCCESS)
Main PID: 716 (nginx)
Tasks: 9 (limit: 9505)
Memory: 17.6M
CPU: 278ms
CGroup: /system.slice/nginx.service
├─ 716 nginx: master process /usr/sbin/nginx -g daemon on; master_process on;
├─4034 nginx: worker process
├─4035 nginx: worker process
├─4036 nginx: worker process
├─4037 nginx: worker process
├─4038 nginx: worker process
├─4039 nginx: worker process
├─4040 nginx: worker process
└─4041 nginx: worker process
ago 05 15:08:52 librenms systemd[1]: Starting A high performance web server and a reverse proxy server…
ago 05 15:08:53 librenms systemd[1]: Started A high performance web server and a reverse proxy server.
ago 05 15:10:43 librenms systemd[1]: Reloading A high performance web server and a reverse proxy server.
ago 05 15:10:43 librenms systemd[1]: Reloaded A high performance web server and a reverse proxy server.
ago 05 15:20:10 librenms systemd[1]: Reloading A high performance web server and a reverse proxy server.
ago 05 15:20:10 librenms systemd[1]: Reloaded A high performance web server and a reverse proxy server.
ago 05 15:20:45 librenms systemd[1]: Reloading A high performance web server and a reverse proxy server.
ago 05 15:20:45 librenms systemd[1]: Reloaded A high performance web server and a reverse proxy server.
ago 05 15:47:44 librenms systemd[1]: Reloading A high performance web server and a reverse proxy server.
ago 05 15:47:44 librenms systemd[1]: Reloaded A high performance web server and a reverse proxy server.
root@librenms:/opt/librenms# service php8.1-fpm status
● php8.1-fpm.service - The PHP 8.1 FastCGI Process Manager
Loaded: loaded (/lib/systemd/system/php8.1-fpm.service; enabled; vendor preset: enabled)
Active: active (running) since Fri 2022-08-05 15:47:49 CEST; 23s ago
Docs: man:php-fpm8.1(8)
Process: 4053 ExecStartPost=/usr/lib/php/php-fpm-socket-helper install /run/php/php-fpm.sock /etc/php/8.1/fpm/pool.d/www.conf 81 (code=exited, st>
Main PID: 4047 (php-fpm8.1)
Status: “Processes active: 0, idle: 4, Requests: 0, slow: 0, Traffic: 0req/sec”
Tasks: 5 (limit: 9505)
Memory: 12.6M
CPU: 71ms
CGroup: /system.slice/php8.1-fpm.service
├─4047 php-fpm: master process (/etc/php/8.1/fpm/php-fpm.conf)
├─4049 php-fpm: pool librenms
├─4050 php-fpm: pool librenms
├─4051 php-fpm: pool www
└─4052 php-fpm: pool www
ago 05 15:47:49 librenms systemd[1]: Starting The PHP 8.1 FastCGI Process Manager…
ago 05 15:47:49 librenms systemd[1]: Started The PHP 8.1 FastCGI Process Manager.
| LibreNMS | 22.7.0-46-g36e7a7793 |
| DB Schema | Not Connected (0) |
| PHP | 8.1.8 |
| Python | 3.9.2 |
| Database | Not Connected |
| RRDTool | 1.7.2 |
| SNMP | 5.9 |
[OK] Composer Version: 2.3.10
cat /opt/librenms/logs/librenms.log
Next Illuminate\Database\QueryException: SQLSTATE[HY000] [1045] Accesso non consentito per l’utente (( it means: access denied for user )) : ‘librenms’@‘localhost’ (Password: NO) (SQL: select * from config where (config_name = snmp.unescape) limit 1) in /opt/librenms/vendor/laravel/framework/src/Illuminate/Database/Connection.php:712
Stack trace:
#0 /opt/librenms/vendor/laravel/framework/src/Illuminate/Database/Connection.php(672): Illuminate\Database\Connection->runQueryCallback()
#1 /opt/librenms/vendor/laravel/framework/src/Illuminate/Database/Connection.php(376): Illuminate\Database\Connection->run()
#2 /opt/librenms/vendor/laravel/framework/src/Illuminate/Database/Query/Builder.php(2414): Illuminate\Database\Connection->select()
#3 /opt/librenms/vendor/laravel/framework/src/Illuminate/Database/Query/Builder.php(2402): Illuminate\Database\Query\Builder->runSelect()
#4 /opt/librenms/vendor/laravel/framework/src/Illuminate/Database/Query/Builder.php(2936): Illuminate\Database\Query\Builder->Illuminate\Database\Query{closure}()
#5 /opt/librenms/vendor/laravel/framework/src/Illuminate/Database/Query/Builder.php(2403): Illuminate\Database\Query\Builder->onceWithColumns()
#6 /opt/librenms/vendor/laravel/framework/src/Illuminate/Database/Eloquent/Builder.php(625): Illuminate\Database\Query\Builder->get()
#7 /opt/librenms/vendor/laravel/framework/src/Illuminate/Database/Eloquent/Builder.php(609): Illuminate\Database\Eloquent\Builder->getModels()
#8 /opt/librenms/vendor/laravel/framework/src/Illuminate/Database/Concerns/BuildsQueries.php(294): Illuminate\Database\Eloquent\Builder->get()
#9 /opt/librenms/vendor/laravel/framework/src/Illuminate/Database/Eloquent/Builder.php(474): Illuminate\Database\Eloquent\Builder->first()
#10 /opt/librenms/vendor/laravel/framework/src/Illuminate/Database/Eloquent/Builder.php(508): Illuminate\Database\Eloquent\Builder->firstOrNew()
#11 /opt/librenms/vendor/laravel/framework/src/Illuminate/Support/Traits/ForwardsCalls.php(23): Illuminate\Database\Eloquent\Builder->updateOrCreate()
#12 /opt/librenms/vendor/laravel/framework/src/Illuminate/Database/Eloquent/Model.php(2132): Illuminate\Database\Eloquent\Model->forwardCallTo()
#13 /opt/librenms/vendor/laravel/framework/src/Illuminate/Database/Eloquent/Model.php(2144): Illuminate\Database\Eloquent\Model->__call()
#14 /opt/librenms/LibreNMS/Config.php(259): Illuminate\Database\Eloquent\Model::__callStatic()
#15 /opt/librenms/LibreNMS/Config.php(471): LibreNMS\Config::persist()
#16 /opt/librenms/LibreNMS/Config.php(60): LibreNMS\Config::processConfig()
#17 /opt/librenms/app/Providers/ConfigServiceProvider.php(27): LibreNMS\Config::load()
#18 /opt/librenms/vendor/laravel/framework/src/Illuminate/Container/BoundMethod.php(36): App\Providers\ConfigServiceProvider->boot()
#19 /opt/librenms/vendor/laravel/framework/src/Illuminate/Container/Util.php(40): Illuminate\Container\BoundMethod::Illuminate\Container{closure}()
#20 /opt/librenms/vendor/laravel/framework/src/Illuminate/Container/BoundMethod.php(93): Illuminate\Container\Util::unwrapIfClosure()
#21 /opt/librenms/vendor/laravel/framework/src/Illuminate/Container/BoundMethod.php(37): Illuminate\Container\BoundMethod::callBoundMethod()
#22 /opt/librenms/vendor/laravel/framework/src/Illuminate/Container/Container.php(653): Illuminate\Container\BoundMethod::call()
#23 /opt/librenms/vendor/laravel/framework/src/Illuminate/Foundation/Application.php(924): Illuminate\Container\Container->call()
#24 /opt/librenms/vendor/laravel/framework/src/Illuminate/Foundation/Application.php(905): Illuminate\Foundation\Application->bootProvider()
#25 [internal function]: Illuminate\Foundation\Application->Illuminate\Foundation{closure}()
#26 /opt/librenms/vendor/laravel/framework/src/Illuminate/Foundation/Application.php(906): array_walk()
#27 /opt/librenms/vendor/laravel/framework/src/Illuminate/Foundation/Bootstrap/BootProviders.php(17): Illuminate\Foundation\Application->boot()
#28 /opt/librenms/vendor/laravel/framework/src/Illuminate/Foundation/Application.php(237): Illuminate\Foundation\Bootstrap\BootProviders->bootstrap()
#29 /opt/librenms/vendor/laravel/framework/src/Illuminate/Foundation/Console/Kernel.php(310): Illuminate\Foundation\Application->bootstrapWith()
#30 /opt/librenms/vendor/laravel/framework/src/Illuminate/Foundation/Console/Kernel.php(127): Illuminate\Foundation\Console\Kernel->bootstrap()
#31 /opt/librenms/app/Console/Kernel.php(72): Illuminate\Foundation\Console\Kernel->handle()
#32 /opt/librenms/artisan(37): App\Console\Kernel->handle()
#33 {main}
