We installed LibreNMS on a new RHEL Server
- Red Hat Enterprise Linux release 9.7 (Plow)
- PHP Version: 8.8.30
- Nginx Version: nginx/1.20.1
- MariaDB Verison: 15.1
- SNMP Version: 5.9.1
We have 2 problems:
GitHub Warning in validate.php
validate.php says:
[WARN] Your install is over 24 hours out of date, last update: Thu, 12 Mar 2026 23:52:38 +0000
Modified Files:
.editorconfig
.env.example
.git-blame-ignore-revs
.github/FUNDING.yml
.github/ISSUE_TEMPLATE/bug_report.yml
.github/ISSUE_TEMPLATE/config.yml
.github/ISSUE_TEMPLATE/device_bug.yml
.github/PULL_REQUEST_TEMPLATE.md
.github/ci-reporter.yml
.github/label-actions.yml
.github/lock.yml
.github/no-response.yml
.github/stale.yml
.github/workflows/announcements.yml
.github/workflows/doc.yml
and 16106 more…
When we run the command ./scripts/github-remove some file permissions are lost
- sudo chown -R librenms:librenms /opt/librenms
- sudo chmod -R 775 /opt/librenms/
- sudo chcon -R -t httpd_sys_content_t /opt/librenms/html
- sudo chcon -R -t httpd_sys_rw_content_t /opt/librenms/storage
- sudo chcon -R -t httpd_sys_rw_content_t /opt/librenms/bootstrap/Cache
APP_KEY does not match key
[FAIL] APP_KEY does not match key used to encrypt data. APP_KEY must be the same on all nodes.
If you rotated APP_KEY, run lnms key:rotate to resolve.
The command lnms key:rotate to resolve. did not resolve the problem
Here the complete validate.php output
[librenms@K3003MGM012TNMS ~]$ ./validate.php
LibreNMS | 26.3.0-dev.102+3a4d0c9e3 (2026-03-13T00:52:38+01:00)
DB Schema | 2026_03_05_112733_ospfv3_instances_nullable (372)
PHP | 8.3.30
Python | 3.9.25
Database | MariaDB 10.5.29-MariaDB
RRDTool | 1.7.2
SNMP | 5.9.1
[OK] Composer Version: 2.9.5
\[FIX\]:
\[FIX\]:
\[FIX\]:
Modified Files:
.editorconfig
.env.example
.github/FUNDING.yml
.github/lock.yml
.github/stale.yml
and 16106 more...
