I tried Reddit and tried the Docker forums, but haven’t gotten any bites, so here goes…
I am looking to install LibreNMS as a Docker container on my Ubuntu 20.04 server. Currently I have two other containers running using the macvlan network type (e.g. each container gets its own MAC address and IP).
The problem I am running into, specifically w/LibreNMS but also other apps (such as Greylog) is with the “sidecar containers”, e.g. librenms_db, librenms_dispatcher, et al…
I recently discovered there are limitations within Docker that prevent containers from directly communicating with the host as well as other containers, so I’m curious if I can even accomplish installing LibreNMS using macvlan? I’ve read of a kludgey workaround to somehow bridge the host’s network adapter to the Docker bridge (or a macvlan interface) but that’s not very elegant.
It seems like the containers will start, but cannot communicate with one another even if I edit the ${ENV} variables to provide the IP addresses I’m assigning the sidecar containers for the various services… tl;dr: is there any way to run LibreNMS entirely as one container, or use the official images including sidecar containers, but as macvlans?
