I am on a quest to install a bandwidth monitor that will live in a container(s) on my Mikrotik Router.
For the project I am using a RB5009, but ultimately plan to run these on Mikrotik HAP AX3, to help some friends and family to have some more info on their home network than just the basic graphs Mikrotik supply.
So, after quite a bit forwards and backwards on Mikrotik forums, LibreNMS was one of the solutions put forward, and overall feedback on LibreNMS is also quite good.
At the moment the status quo is that librenms/librenms:latest is up and running, as well as MariaDB. Each in it’s own container.
More info on steps etc here (Containerized SNMP monitoring (short term) - a step above built-in graphs - MikroTik)
I am new to LibreNMS, so would like to get some pointers and suggestions as to where to go next.
I am currently able to log on to LibreNMS, and add devices (so, the DB connection is also working)
However, I can see there is no automated polling / discovery.
The plan is for a relatively basic system advising which Wifi Access Points on my LAN is up / down, and how much each of these are generating in terms of traffic. Also, most importantly, how much of my internet capacity is being used.
Thus, because of the relatively basic requiremens, and the need to keep it super lightweight, I need some guidance from all of you here on this forum please.
[I do not want to end up with too many sidecars (just essentials to get it working)
At this point in time it seems I need a polling mechanism, and timing it o execute according to a schedule.
It seems CRON is replaced by a sidecar ?Dispatcher? service, which in turn seems to be dependant on a Redis service… Quite a bit for a newbie to take in.
So, my questions to you all are:
- How do I keep it as lightweight as possible, but able to do the basics (in containers)?
- Assistance to try and get it all working on the Mikrotik platform (slightly different container implementation)
- Best practices advise.
My validate.php results
ConfigurationOk
DatabaseFailure
OK: Database Schema is current
OK: SQL Server meets minimum requirements
OK: lower_case_table_names is enabled
OK: MySQL engine is optimal
OK: Database and column collations are correct
OK: Database schema correct
FAIL: Time between this server and the mysql database is off Mysql time 2023-11-23 11:40:59 PHP time 2023-11-23 13:40:59
DependenciesOk
DiskOk
DistributedpollerOk
MailOk
PhpOk
PollerFailure
FAIL: No active polling method detected
OK: Dispatcher Service not detected
OK: Locks are functional
FAIL: No python wrapper pollers found
OK: Redis is unavailable
ProgramsFailure
INFO: fping FAILURES can be ignored if running LibreNMS in a jail without ::1. You may want to test it manually: fping ::1
FAIL: /usr/sbin/fping could not be executed. /usr/sbin/fping must have CAP_NET_RAW capability (getcap) or suid. Selinux exclusions may be required. (/usr/sbin/fping: can’t create socket (must run as root?))
FAIL: /usr/sbin/fping should have CAP_NET_RAW!
Fix:
setcap cap_net_raw+ep /usr/sbin/fping
FAIL: /usr/sbin/fping6 could not be executed. /usr/sbin/fping6 must have CAP_NET_RAW capability (getcap) or suid. Selinux exclusions may be required. (/usr/sbin/fping: can’t create socket (must run as root?))
FAIL: /usr/sbin/fping6 should have CAP_NET_RAW!
Fix:
setcap cap_net_raw+ep /usr/sbin/fping6
PythonFailure
FAIL: Python3 module issue found: ‘’
Fix:
pip3 install -r /opt/librenms/requirements.txt
RrdOk
RrdcheckOk
SchedulerOk
SystemOk
UpdatesWarning
WARN: Non-git install, updates are manual or from package
UserOk
WebserverFailure
FAIL: ServerName is set incorrectly for your webserver, update your webserver config. 172.xxx.1.6 parse failure (/validate/results)
Fix:
ServerName 172.xxx.1.6
Thanks in advance
