Interface traffic - high values
I have a problem with my graphs. I see a lot of spikes on monthly and longer time period graphs. Today I ran rrd_tune and lnms port:tune IPaddress. How can I fix this?
librenms@librenms:~$ lnms config:get --dump | jq | grep rrd
  "nfsen_rrds": [
  "norrd": false,
  "rrd": {
  "rrd_purge": 0,
  "rrd_rra": " RRA:AVERAGE:0.5:1:2016 RRA:AVERAGE:0.5:6:1440 RRA:AVERAGE:0.5:24:1440 RRA: RRA:MAX:0.5:24:1440 RRA:MAX:0.5:288:1440 RRA:LAST:0.5:1:2016 ",
  "rrdgraph_def_text": "-c BACK#EEEEEE00 -c SHADEA#EEEEEE00 -c SHADEB#EEEEEE00 -c CANVAS#
  "rrdgraph_def_text_dark": "-c BACK#EEEEEE00 -c SHADEA#EEEEEE00 -c SHADEB#EEEEEE00 -c CA
  "rrdgraph_def_text_color": "000000",
  "rrdgraph_def_text_color_dark": "f8f9f9",
  "rrdgraph_real_percentile": false,
  "rrdtool": "/usr/bin/rrdtool",
  "rrdtool_tune": true,
  "rrdtool_version": "1.7.2",
  "ping_rrd_step": 300,
    "dir": "/var/lib/smokeping/rrd"
  "rrdcached": "unix:/run/rrdcached.sock",
  "rrd_dir": "/data/librenms/rrd",
./validate.php output:
LibreNMS  | 26.2.0 (2026-02-16T13:13:17+01:00)
DB Schema | 2026_02_13_000000_change_stp_top_changes_to_unsigned_int (365)
PHP       | 8.3.6
Python    | 3.12.3
Database  | MariaDB 10.11.14-MariaDB-0ubuntu0.24.04.1
SNMP      | 5.9.4.pre2
[OK]    Composer Version: 2.9.5
[INFO]  Could not read cron files
[OK]    Redis is unavailable
[WARN]  IPv6 is disabled on your server, you will not be able to add IPv6 devices.
