Invalid Credentials
I woke up this morning unable to log in to my LibreNMS. Using the same credentials I’ve used since first set up, about two months ago. I’m a 15 yr vet of Nagios w/ many custom checks I’ve written. I’ve changed nothing on the server or Docker install/config. I’ve found nothing yet in the logs to indicate any error. I have seen a number of deprecation warnings but nothing that seems related to a problem connecting to the DB or other. Since this is such a new install having to reinstall isn’t the end of the world, but as a SysAdmin, knowing and resolving the issue would be my preferred outcome. I don’t want to have to experience this issue again, for obvious reasons.
To start, does it have anything to do with …:edge release of the docker image? I, like a rookie, missed that in my initial deployment. Is there a stable? I’m thinking your “edge” tag is latest?
docker-compose.yml
version: "3.5"
x-env-global: &env-global
  - &MYSQL_DATABASE "librenms"
  - &MYSQL_USER "librenms"
  - &MYSQL_PASSWORD <obfuscated>
  - &TZ "America/Phoenix"
  - &PUID "1001"
  - &PGID "999"
x-envlibrenms: &envlibrenms
  MEMORY_LIMIT: "256M"
  UPLOAD_MAX_SIZE: "16M"
  OPCACHE_MEM_SIZE: "128"
  REAL_IP_FROM: "0.0.0.0/32"
  REAL_IP_HEADER: "X-Forwarded-For"
  LOG_IP_VAR: "remote_addr"
  LIBRENMS_SNMP_COMMUNITY: <obfuscated>
  MEMCACHED_HOST: "memcached"
  MEMCACHED_PORT: "11211"
  LIBRENMS_WEATHERMAP: "true"
  LIBRENMS_WEATHERMAP_SCHEDULE: "*/5 * * * *"
services:
  db:
    image: mariadb:10.4
    command:
      - "mysqld"
      - "--innodb-file-per-table=1"
      - "--lower-case-table-names=0"
      - "--character-set-server=utf8"
      - "--collation-server=utf8_unicode_ci"
    volumes:
      - ${PWD}/librenms/db:/var/lib/mysql
    environment:
      TZ: *TZ
      #MYSQL_ALLOW_EMPTY_PASSWORD: "yes"
      MYSQL_DATABASE: *MYSQL_DATABASE
      MYSQL_USER: *MYSQL_USER
      MYSQL_PASSWORD: *MYSQL_PASSWORD
      MYSQL_ROOT_PASSWORD: <obfuscated>
    networks:
      - librenms_network
    restart: always
  memcached:
    image: memcached:alpine
    environment:
      TZ: *TZ
    networks:
      - librenms_network
    restart: always
  redis:
    image: redis:5.0-alpine
    environment:
      TZ: *TZ
    restart: always
  librenms:
    image: librenms/librenms:edge
    hostname: librenms
    cap_add:
      - NET_ADMIN
      - NET_RAW
    ports:
      - 8999:8000
    depends_on:
      - db
      - memcached
    volumes:
      - ${PWD}/librenms/librenms:/data
      - ${PWD}/snmp_conf/snmpd.conf:/etc/snmp/snmpd.conf
    environment:
      <<: *envlibrenms
      TZ: *TZ
      PUID: *PUID
      PGID: *PGID
      DB_HOST: "db"
      DB_NAME: *MYSQL_DATABASE
      DB_USER: *MYSQL_USER
      DB_PASSWORD: *MYSQL_PASSWORD
      DB_TIMEOUT: "60"
    networks:
      - librenms_network
    restart: always
  dispatcher:
    hostname: librenms-dispatcher-1234
    cap_add:
      - NET_ADMIN
      - NET_RAW
    depends_on:
      - librenms
      - redis
    volumes:
    environment:
      <<: *envlibrenms
      TZ: *TZ
      PUID: *PUID
      PGID: *PGID
      DB_HOST: "db"
      DB_TIMEOUT: "60"
      DISPATCHER_NODE_ID: "dispatcher1234"
      REDIS_HOST: "redis"
      REDIS_PORT: "6379"
      REDIS_DB: "0"
      SIDECAR_DISPATCHER: "1"
    networks:
      - librenms_network
    restart: always
  dispatcher2:
    hostname: librenms-dispatcher-5678
    cap_add:
      - NET_ADMIN
      - NET_RAW
    depends_on:
      - librenms
      - redis
    volumes:
    environment:
      <<: *envlibrenms
      TZ: *TZ
      PUID: *PUID
      PGID: *PGID
      DB_HOST: "db"
      DB_TIMEOUT: "60"
      DISPATCHER_NODE_ID: "dispatcher5678"
      REDIS_HOST: "redis"
      REDIS_PORT: "6379"
      REDIS_DB: "0"
    networks:
      - librenms_network
    restart: always
  syslogng:
    hostname: librenms-syslogng
    cap_add:
      - NET_ADMIN
      - NET_RAW
    depends_on:
      - librenms
    volumes:
    environment:
      <<: *envlibrenms
      TZ: *TZ
      PUID: *PUID
      PGID: *PGID
      DB_HOST: "db"
      DB_TIMEOUT: "60"
      SIDECAR_SYSLOGNG: "1"
    networks:
      - librenms_network
    restart: always
networks:
  librenms_network:
    external:
Enter LibreNMS container and run ./daily.sh and ./validate.php
[email protected]:(10.0.2.249)~/DockerServices/librenms$ docker exec -it -u librenms librenms_librenms_1 bash
bash-5.0$ cd /opt/librenms/
bash-5.0$ ./daily.sh
Updating SQL-Schema                                OK
Cleaning up DB                                     OK
bash-5.0$ ./validate.php
LibreNMS  | 1.70.1
DB Schema | 2021_02_09_084318_remove_perf_times (199)
PHP       | 7.3.25
Python    | 3.8.5
MySQL     | 10.4.17-MariaDB-1:10.4.17+maria~focal
SNMP      | NET-SNMP 5.8
OpenSSL   |
[OK]    Installed from the official Docker image; no Composer required
[WARN]  Your database schema has extra migrations (2020_09_18_230114_create_service_templates_device_group_table, 2020_09_18_230114_create_service_templates_device_table, 2020_09_18_230114_create_service_templates_table, 2020_09_18_230114_extend_services_table_for_service_templates_table, 2020_09_19_230114_add_foreign_keys_to_service_templates_device_group_table, 2020_09_19_230114_add_foreign_keys_to_service_templates_device_table, 2021_02_08_224355_fix_invalid_dates, 2021_02_09_084318_remove_perf_times). If you just switched to the stable release from the daily release, your database is in between releases and this will be resolved with the next release.
[WARN]  IPv6 is disabled on your server, you will not be able to add IPv6 devices.
[WARN]  Log rotation not enabled, could cause disk space issues
        sudo cp /opt/librenms/misc/librenms.logrotate /etc/logrotate.d/librenms
[WARN]  Updates are managed through the official Docker image
bash-5.0$
How is it that I see a [WARN] issue with the DB Schema and then the very next line states [OK]? And still unable to log in.
Thank you
A post was merged into an existing topic: Unable to log in to my LibreNMS
