Hi!
After installing LibreNMS I am really happy about this great software! For me the next step is to try to change the authentication to OpenLDAP. In the librenms-DB, my users table has already the following items (from working SQL authentication):
select * from users;
| user_id | auth_type | auth_id | username | password | realname | email | descr | level | can_modify_passwd | created_at | updated_at | remember_token |
| 1 | mysql | 1 | librenms | $123456… | | [email protected] | | 10 | 1 | 2018-12-30 20:49:11 | 2019-01-05 14:54:40 | 123456… |
| 2 | mysql | 2 | Gast | 123456… | | | | 1 | 1 | 2019-01-05 18:38:16 | 2019-01-05 19:29:43 | 123456… |
Now with LDAP in WebUI, the following error occures:
Unhandled MySQL Error [22007]
SQLSTATE[22007]: Invalid datetime format: 1366 Incorrect integer value: ‘****’ for column ‘auth_id’ at row 1
Check your log for more details. (librenms.log)
librenms.log:
Next Illuminate\Database\QueryException: SQLSTATE[22007]: Invalid datetime format: 1366 Incorrect integer value: ‘*****’ for column
‘auth_id’ at row 1 (SQL: insert into users
(descr
, realname
, email
, can_modify_passwd
, username
, level
, auth_type
, auth_id
, updated_at
, created_at
) values (, , , 0, *****, 10, ldap, *****, 2019-01-06 12:48:00, 2019-01-06 12:48:00)) in /opt
/librenms/vendor/laravel/framework/src/Illuminate/Database/Connection.php:647
./validate.php
Component | Version |
LibreNMS | 1.47 |
DB Schema | 275 |
PHP | 7.2.12 |
MySQL | 5.5.60-MariaDB |
RRDTool | 1.4.8 |
SNMP | NET-SNMP 5.7.2 |
[OK] Composer Version: 1.8.0
auth_test.php -l shows all users:
/opt/librenms/scripts/auth_test.php -l
Authentication Method: ldap
Users: (0), 123 (0), 456 (0), 789 (0), …
Version | 1.47 - Sun Dec 30 2018 15:29:16 GMT+0100 |
DB Schema | #275 |
Web Server | nginx/1.12.2 |
PHP | 7.2.12 |
RRDtool | 1.4.8 |
Downloaded as virtual Image.
Has anyone an idea why LibreNMS wants to insert a timestamp in column ‘auth_id’ by LDAP auth.?
Best Regards
Christopher
