Inventory not show
After tonight update no more inventory list for Cisco devices. Any suggestions?
My inventory list still works for cisco devices,
I wonder if this is to do with PHP memory? you could try increase it with $config[‘php_memory_limit’] = 512; in config.php
Also try
Run https://server/inventory/debug=yes/
Check your javascript console for errors
Comparable (if not same) issue here. I cannot see the inventory into the device page itself on Cisco Switch and Huawei Switch. No issue on a linux server for instance.
Opening the global inventory is fine.
No change with PHP memory limit increased. And nothing when loading page with debug=yes. Javascript console is not helping either.
Will let you know if I find a direction to dig in.
Bye
PipoCanaja
