I am running 4 Nexus 93108’s and running VXLAN and anycast-gateway for 4 vlans…
What is a good way to have these devices discovered? Right now, one of them is on the shared anycast gateways, 2 are were found using a HSRP IP, and one of them is using a L3 subnet.
I’d like all of them to maybe use the loopback address, or some other L3 that is on each of them.
Can you change the IP address they were discovered with to one of the many that these devices have? How do you do it, and will it stay with discovery running?
