I have a World Map setup for monitoring multiple locations. This is just for our network devices to see when they do down. I’ve been using the LibreNMS account for setting up monitoring, templates, and widgets. However, we have a few people that will be actually watching this map, so the VM will be accessed from a few desks. I created a new generic user, and found that I can’t log in as LibreNMS in one tab and the generic user in another. I wanted to do this for applying changes to the generic account and verifying the results. Instead, I have to log out and log in as the generic user to verify results. I also tested to see if more than one instance of the generic user can be logged in, which it can be. However, anything clicked on in one tab, will have the same result in every other logged in instance.
Is there a way to be able to have the LibreNMS account and another account logged in simultaneously? Also, can a generic user account be setup to run its own separate session so multiple instances of it can run without affecting other logins?
Hope that makes sense… I’m on limited coffee this morning
