LibreNMS---->L3 device(SNMP monitored)----->PE gateway 1
V
PE gateway 2
1, PE gateways are managed by 3rd party and they won’t allow SNMP monitoring.
2, librenms monitoring network is isolated and have no internet or other network access.
3, I’m not certain if L3 device support feature like IP SLA, for testing network quality.
Is it possible to do something like L3 device collecting ping status of PE gateways and sending results back thru SNMP back to libreNMS ?.
Perform ping monitor of PE gateways from L3 device and show link status on librenms ?.
This is not the feature i’m looking for. SNMP proxy require access and snmp configuration on both devices.
On full featured network devices with full SNMP support, we can configure something like IP SLA(cisco) or NQA(Comware/Aruba) sending icmp-echo to ISP equipment. And when the echo fail after configured threshold, generate & send SNMP trap back to NMS system.
The L3 device mentioned above in example do not have IP SLA like feature. Thus the question of possibility of invoking and reading ping results thru SNMP.
Unfortunately, on-premises PE device is a L2 switch and with actual PE gateway ip configured elsewhere. Hence the L3 device ports don’t go down unless cable disconnected.
As i mentioned earlier, the L3 device in question is not a cisco device and do not have similar feature. But I have enabled “Service Level Agreement Tracking” poller module for all network devices.
On your example, are you getting SLA over poller module or used and SNMP traps to get alerts ?.
Maybe you should define a route on the L3 device in conjunction with ACL so that LibreNMS can reach the host on the other network with the ping, and then receive the response.
For security, it would also be important to have an ACL on the host to be monitored, so that it only responds to pings from LibreNMS.
