Hey guys,
Short question:
Is there an easy way to export a list of devices including ip,hostname,os as a csv or list from librenms?
Hey guys,
Short question:
Iâm not sure about the webui, but you could always do select ip,hostname,os from devices or use the API.
I went the api->powershell way, thanks for your suggestions
Nice, you should post your command here for others
well a very short example is this:
# define the url/adress of your librenms server ( leave /api/v0/ intact)
$baseurl = "http://librenms.lol/api/v0/"
#fill in api token which you can retrieve from web interface
$token = "your api token"
# generating header(do not touch)
$header = @{
"X-Auth-Token" = $token}
#defining url to get devices
$gdevices = $baseurl + "devices?type=network"
#invoking api request and showing results in grid view
Invoke-RestMethod -uri $gdevices -Headers $header |select -ExpandProperty devices -ExcludeProperty sysDescr |ogv
As Aauvinet found out below: the invoke-restmethod command is not available in powershell 2 or below. please installl windows Management framework 5 (which includes a newer version of powershell) or above to work around this .
I try you scrip in poweshell⌠but i donât work to me
I do :
I open powershell
I put in cli
$baseurl = "http://librenms.my/api/v0/"
$token = âremovedâ
$header = @{
âX-Auth-Tokenâ = $token}
But Invoke-RestMethod isnât know by powershell
did you change the url to reflect your url?
Invoke-RestMethod has been added in powershell v3.0 you are probably trying to execute the command on a windows 7 or server 2008 machine. please try on newer windows version or install windows management framework 5 or later
https://www.microsoft.com/en-us/download/details.aspx?id=54616
if you want to see the powershell version of your machine please type $psversiontable in your powershell window
Unburying this thread, I try to obtain a list of all my network devices.
So far, it seems that ?type=network does not work anymore.
My request is:
curl -H 'X-Auth-Token: MyFavoriteAPIToken' 'http://localhost/api/v0/devices/?type=network'
This returns a list of all equipments, firewalls, servers etc, not limited to network.
Having read the documentation at https://docs.librenms.org/API/Devices/#get_device, I canât find the answer.
So far, I have mostly HP switches so I workaround the issue by doing :
curl -H 'X-Auth-Token: MyFavoriteAPIToken' 'http://localhost/api/v0/devices/?type=os&query=procurve'
Is there a âgoodâ way to get only network devices from an API query ?
Best regards.
I created a Python-script to recursively crawl all network devices for relevant information. In my case I specifically wanted all serial numbers of all devices (and parts) in LibreNMS.
# -*- coding: utf-8 -*-
Created on Tue Sep 22 13:41:25 2020
Crawl libreNMS inventory to receive list of all devices with serial number.
import csv
import requests
#edit base url below
base_url = 'http://librenms.me/api/v0/'
#edit auth-token below
auth_token = 'INSERT Auth-Token here'
header = { 'x-auth-token' : auth_token }
file_path = 'LibreNMSInventory.csv'
#General GET helper function, pass sub-url to append to base URL for request
def GET(url):
return requests.get('{0}{1}'.format(base_url,url), headers = header)
#GET call to get all devices registered in libreNMS
#Return dictionary of all deviceIDs + hostname
def getDeviceDict():
device_list = GET('devices/').json()['devices']
device_dict = {}
for device in device_list:
device_dict[device['device_id']] = device['hostname']
return device_dict
def inventoryList(deviceID, hostname, physical_id = None):
if physical_id == None:
postString =""
else:
postString="?entPhysicalContainedIn={}".format(physical_id)
inventory = GET('inventory/{0}{1}'.format(deviceID,postString)).json()['inventory']
for device in inventory:
entPhysicalClass = device['entPhysicalClass']
entPhysicalName = device['entPhysicalName']
entPhysicalDescr = device['entPhysicalDescr']
entPhysicalModelName = device['entPhysicalModelName']
entPhysicalSerialNum = device['entPhysicalSerialNum']
if device['entPhysicalSerialNum'] != '':
csv_row = [hostname, entPhysicalClass, entPhysicalName, entPhysicalDescr, entPhysicalModelName, entPhysicalSerialNum]
print(csv_row)
with open(file_path,'a', newline='') as file:
writer = csv.writer(file)
writer.writerow(csv_row)
# print('{0},{1},{2},{3},{4},{5}'.format(hostname,entPhysicalClass,entPhysicalName,entPhysicalDescr,entPhysicalModelName,entPhysicalSerialNum))
inventoryList(deviceID,hostname,device['entPhysicalIndex'])
def main():
device_dict = getDeviceDict()
with open(file_path,'w+', newline='') as file:
writer.writerow(['Hostname','Class','Name','Description','Model Name','Serial'])
for deviceID, hostname in device_dict.items():
inventoryList(deviceID,hostname)
main()
