i need a “snmp_set” or equivalent
is this implemented in LNMS ?
tried to find, but … maybe i am missing something?
i need “snmp_set” because one sensor i want to use is acting as capacitor in electronics, so it is “pumped” with max value but it is not cleared,
After reading sensor, one need to write zero to specific OID and reset sensor
after all, i implemented snmp_set in my local install
it was almost easy one good starting point was snmp_get
so, it is working for me
but yes, LNMS is readonly, so … dont think it is worth of PR
my case is specific
