As the title suggests, does LibreNMS purge old syslog data?
If not can it? Can I delete stuff manually?
Thanks in advance
tslytsly
Thanks in advance
tslytsly
This is covered in the docs: http://docs.librenms.org/Support/Configuration/#cleanup-options
Thanks @laf
Is there a way to manually do it?
BTW, I’m not offended if you just say RTFM
To manually do it just delete them from the database table.
That bit isn’t covered in docs but re-running ./daily.sh
will work
Thanks for the suggestions guys.
Just in case this helps anyone in the future (and in case I forget what I did!):
I entered $config['syslog_purge'] = 1;
in config.php
, ran ./daily.sh
and then set the purge time back to 30.
