I have a device with 2 different web pages on different ports, can I set a URL for a second button to open from the device menu to access the second page?
You could have a fiddle with the options mentioned here Customizing the Web UI - LibreNMS Docs
Thank you for the suggestion.
Apologies but I’ve hosed my install. Luckily it’s my “B” install and not too important.
I typed the following command to try and change the port, of my ProxMox Server, WebUI. (it runs on port 8006, not 80, not 443)
lnms config:set html.device.links.+ ‘{“url”: “https://192.168.0.250:8006/{{ $device->192.168.0.250 }}”, “title”: “Open-8006”}’
That’s the result (for all my systems)
If you could advise how I can clear my obviously erroneous change, I can fiddle until I learn how to do this properly. I assume it’s a pretty simple thing I messed up.
Ok so I’ve since blown away my entire install, created a custom php file but I’m not finding a menu for it.
I think I have this guys problem:
"Still can not edit per device menu"
“Adding this line adds an icon on every device.
I would like to add this icon on certain device with certain url.”
Exactly this, some of my devices I would like to change the WebURL to be on a different port.
Some devices I’d like 2 or even 3 different launches to the device.
(Different ports and or different URLS)
Example I have printers, with a web administration menu available here:
https://:443/wcd/top.xml
http://:50443/panel/top.html
Same device, 2 different web administration panels for it. different URL and different port.
So it really varies, per device what I would like to configure for the Web Interface links.
