Is there any way to make alert based on running processes/load averages?
I am trying to create alert based on running processes (device_hr_processes) or load averages(device_ucd_load) (check Graphs » System)
but cannot find any rules with these options,
any ideas?
regards,
Markus
I don’t believe this information is stored in the database so you can’t alert on it.
So is it only saved into RRD on every poller run, not in DB?
Is there any way to change it?
Correct and not without someone writing code. However that would require a generic handler for this type of info which isn’t available.
thank you for your answer, looks like I need to start coding…
