Mainly looking for a way to see if the service is running and what rules are being applied. I was thinking there might be a snmp extent or agent that could be installed but coming up empty.
Optionally, You could take a look at https://github.com/librenms/librenms-agent/blob/master/snmp/systemd.py
Monitoring iptables directly is not possible. Monitoring if all systemd services are running (with the extend) is possible.
Example:
Otherwise, you will have to create your own extend for the functionality you describe above.
