Dear LibreNMS,
I recently installed the ISC DHCP Stats Application and I would like to suggest 2 ideas for improvement:
Is it possible to add to the Perl script the consideration of
includestatements present in dhcpd.conf? Because when managing many VLANs, it is sometimes practical to organize subnets into specific subfiles. -
The start and end dates of leases are displayed in UTC format. Is it possible to convert them into date of the system on which LibreNMS is installed? This would be really nice as the leases are several hours behind my timezone.
Do you think it’s technically possible?
Thank you.
Best regards,
Auguste
