Dear LibreNMS,
I recently installed the ISC DHCP Stats Application and I observed a possible issue:
From WebUI, Apps > DHCP stats > Leases, the “Vendor” item remains empty for current leases.
Looking more closely at the Perl script, I suppose that this item depends on the “vendor-class-identifier” parameter, added to version 0.1710 of the Net-ISC-DHCPd Perl module.
However, when the module is installed with cpanm Net::ISC::DHCPd::Leases, this is the previous version 0.1709 which is installed as it is still the default version.
I think the reason is that the latest version doesn’t pass the tests:
http://matrix.cpantesters.org/?dist=Net-ISC-DHCPd+0.171
What do you think? Is there any solution?
Thank you for your help.
Best regards,
Auguste
