ISIS Topology Monitoring
Still no IS-IS topology monitor?
Or is it a way?
We’re running Segment Routing now over IS-IS so it would be nice to get a Topology from the IS-IS.
Running this on cisco ncs5501, asr920, ncs540 hardware.
I started making a very basic implementation which can show ISIS-enabled adjacencies and their status. This is still a work in progress but might prove useful.
Enabled today. Great work ottorei
Hi all,
May i know how to make the librenms can monitor ISIS? I’m already enable on GUI but still not appear in the menu.
Thanks and appreciate any feedback
Hi all,
I’m already enable using below step but still not apper in the Menu tab routing “ISIS”. Appreciate any feedback how to check the issue. Also i’m already reboot the server and result still same.
Global Setting → Discovery Module
Global Setting → Poller Module
I have been able to enable ISIS and can see the adjacencies in the web interface. Are they also available through the API? I have not found it. It would be very useful though.
