After running ./daily.sh webpages are not loading.
Here is the output from cat /var/log/nginx/error.log
Stack trace:
#0 /opt/librenms/vendor/laravel/framework/src/Illuminate/Container/Container.php(803): ReflectionClass->__construct(‘App\Http\Kernel’)
#1 /opt/librenms/vendor/laravel/framework/src/Illuminate/Container/Container.php(681): Illuminate\Container\Container->build(‘App\Http\Kernel’)
#2 /opt/librenms/vendor/laravel/framework/src/Illuminate/Foundation/Application.php(785): Illuminate\Container\Container->resolve(‘App\Http\Kernel’, Array, false)
#3 /opt/librenms/vendor/laravel/framework/src/Illuminate/Container/Container.php(265): Illuminate\Foundation\Application->resolve(‘App\Http\Kernel’, Array, false)
#4 /opt/librenms/vendor/laravel/framework/src/Illuminate/Container/Container.php(799): Illuminate\Container\Container->Illuminate\Container{closure}(Object(App\Application), Array)
#5 /opt/librenms/vendor/larav" while reading response header from upstream, client: 10...195, server: librenms.prp.lcl, request: “GET /login HTTP/2.0”, upstream: “fastcgi://unix:/var/run/php-fpm/php7.2-fpm.sock:”, host: “librenms.prp.lcl”
2020/07/08 14:11:28 [error] 101232#0: *5 FastCGI sent in stderr: "PHP message: PHP Warning: include(/opt/librenms/app/Http/Kernel.php): failed to open stream: Permission denied in /opt/librenms/vendor/composer/ClassLoader.php on line 444
PHP message: PHP Warning: include(): Failed opening ‘/opt/librenms/vendor/composer/…/…/app/Http/Kernel.php’ for inclusion (include_path=’.:/usr/share/pear:/usr/share/php’) in /opt/librenms/vendor/composer/ClassLoader.php on line 444
PHP message: PHP Fatal error: Uncaught ReflectionException: Class App\Http\Kernel does not exist in /opt/librenms/vendor/laravel/framework/src/Illuminate/Container/Container.php:803
This is the output from ./validate.php
Component | Version |
LibreNMS | 1.65-17-ga3cd90d |
DB Schema | 2020_06_23_00522_alter_availability_perc_column (170) |
PHP | 7.2.31 |
Python | 3.6.8 |
MySQL | 5.5.65-MariaDB |
RRDTool | 1.4.8 |
SNMP | NET-SNMP 5.7.2 |
[OK] Composer Version: 1.10.8
