I am seeing this error when I run the web install process:
I don’t know what the error means I guess.
Thanks,
J
Thanks,
J
I can connect to the remote database from the install instance properly.
This is an nginx issue.
I resolved the nginx/php issue, but am seeing this error now when walking through the activation…
Starting Update…
SQLSTATE[HY000] [2002] Connection refused (SQL: select * from information_schema.tables where table_schema = librenms and table_name = migrations)
Error!
Any ideas? This is a remote DB I’m trying to connect to, and I can connect directly, just not through the install gui.
Did you resolve this?
