Hi LibreNMS Community.
I’ve got seven Geist PDUs that aren’t reporting any power data in LibreNMS. They have been connected for about 2 weeks now and only able to report up/down, system, and poller status graphs. I just moved these over from my Observium instance previously. Power was successfully reporting in Observium using GEIST-V3-MIB. It appears that the PDUs are being misclassified as an environment device and not a power device. Possibly an OID mismatch? Removing and re-adding the devices did not solve the issue either. I also made sure to run the ./daily.sh
script too.
Geist PDU Models
MNS3E2R1-12P848-3TL6A0E10-S
MNU3EGW1-24PH68-6HW15A9BXX-S-A
Both PDU models are using the Geist IMD3 module for monitoring over SNMP.
Reported Operating System in LibreNMS
Geist Watchdog
Reported Object ID of the Geist IMD3
.1.3.6.1.4.1.21239.42.1.53
I followed some previous help articles to run the .discovery.php -d -h <host ip>
script and .poller-wrapper.py
scripts to see if LibreNMS just didn’t find all the OID’s yet, but that hasn’t made a difference unfortunately. When running the Discovery script against one of the PDUs. It recognizes it’s a Geist PDU and does match on some of the OIDs, but there are a number of lines that report “No Such Object available on this agent at this OID”.
I also ran snmpwalk against the same PDU specifying which MIB file to use with the -m
flag. GEIST-MIB-V3, GEIST-V4-MIB, and GEIST-V5-MIB(I downloaded this from my PDU and added it) in /opt/librenms/mibs/geist
were unable to adopt to the OIDs.
I’m at a loss at the moment and would appreciate some assistance as all my links are purple in Google and my problem still exists. Thanks in advance.
