Hello everyone,
I’ve encountered a problem with my LibreNMS installation and I’m reaching out to the community for some assistance. I recently attempted to change the network type used by my LibreNMS container from “bridge” to “host” in order to enable my LibreNMS server to perform SNMP queries on machines located outside of the containers. However, after making this change, the LibreNMS container fails to start up completely.
Here’s the configuration I used in my docker-compose.yml file:
services:
db:
image: mariadb:10.5
network_mode: host
container_name: librenms_db
command:
- "mysqld"
- "--innodb-file-per-table=1"
- "--lower-case-table-names=0"
- "--character-set-server=utf8mb4"
- "--collation-server=utf8mb4_unicode_ci"
volumes:
- "./db:/var/lib/mysql"
environment:
- "TZ=${TZ}"
- "MYSQL_ALLOW_EMPTY_PASSWORD=yes"
- "MYSQL_DATABASE=${MYSQL_DATABASE}"
- "MYSQL_USER=${MYSQL_USER}"
- "MYSQL_PASSWORD=${MYSQL_PASSWORD}"
restart: always
redis:
image: redis:5.0-alpine
network_mode: host
container_name: librenms_redis
environment:
- "TZ=${TZ}"
restart: always
msmtpd:
image: crazymax/msmtpd:latest
network_mode: host
container_name: librenms_msmtpd
env_file:
- "./msmtpd.env"
restart: always
librenms:
image: librenms/librenms:latest
network_mode: host
hostname: librenms
cap_add:
- NET_ADMIN
- NET_RAW
depends_on:
- db
- redis
- msmtpd
volumes:
- "./librenms:/data"
env_file:
- "./librenms.env"
environment:
- "TZ=${TZ}"
- "PUID=${PUID}"
- "PGID=${PGID}"
- "DB_HOST=db"
- "DB_NAME=${MYSQL_DATABASE}"
- "DB_USER=${MYSQL_USER}"
- "DB_PASSWORD=${MYSQL_PASSWORD}"
- "DB_TIMEOUT=60"
restart: always
dispatcher:
network_mode: host
container_name: librenms_dispatcher
hostname: librenms-dispatcher
cap_add:
- NET_ADMIN
- NET_RAW
depends_on:
- librenms
- redis
volumes:
env_file:
- "./librenms.env"
environment:
- "TZ=${TZ}"
- "PUID=${PUID}"
- "PGID=${PGID}"
- "DB_HOST=db"
- "DB_TIMEOUT=60"
- "DISPATCHER_NODE_ID=dispatcher1"
- "SIDECAR_DISPATCHER=1"
restart: always
syslogng:
network_mode: host
container_name: librenms_syslogng
hostname: librenms-syslogng
cap_add:
- NET_ADMIN
- NET_RAW
depends_on:
- librenms
- redis
volumes:
env_file:
- "./librenms.env"
environment:
- "TZ=${TZ}"
- "PUID=${PUID}"
- "PGID=${PGID}"
- "DB_HOST=db"
- "DB_TIMEOUT=60"
- "SIDECAR_SYSLOGNG=1"
restart: always
snmptrapd:
network_mode: host
container_name: librenms_snmptrapd
hostname: librenms-snmptrapd
cap_add:
- NET_ADMIN
- NET_RAW
depends_on:
- librenms
- redis
volumes:
env_file:
- "./librenms.env"
environment:
- "TZ=${TZ}"
- "PUID=${PUID}"
- "PGID=${PGID}"
- "DB_HOST=db"
- "DB_TIMEOUT=60"
- "SIDECAR_SNMPTRAPD=1"
restart: always
When I attempt to start the container with this configuration, I find that some LibreNMS services appear to start, but others do not. For example, the MySQL database service doesn’t seem to initialize properly, leading to errors during the full startup of the container.
I suspect that the issue is related to the network configuration, but I’m not sure of the best way to resolve it. I’ve checked the container logs and haven’t found any clear indications of the cause of the problem.
Do you have any suggestions on how to troubleshoot this issue? Are there any additional configuration steps I need to consider when changing the network type used by the LibreNMS container?
Any help or advice would be greatly appreciated. Thanks in advance for your assistance!
