There is a latency issue with librenms or something else and I cant figure it out.
I have 2 services setup, nagios ping and icmp, both checking one server. They’ve both been green for about 10 minutes with no issues yet when I click on Devices>>All Devices, the machine is showing Red.
Link to screen:
imgur dot com / LpAylGu
Whats the deal here? I’m testing this for a major datacenter and I cant afford any kind of latency issue, once a server is checked via ping and it shows up, the device needs to eliminate the alert immediately and not have any kind of wait time. Cant afford having people flipping out and running to check a non-issue because they are getting alerts for something that doesnt exist.
I did a basic standard install of librenms so I never actively configured memcache either.
Also, when I did the following:
su librenms
./poller.php -h all
It finally eliminated the device as showing red. This also seems like a major issue because I shouldnt have to actively run anything for the device to come off an alert of any kind
Well I’m testing multiple monitoring systems to see which one to use, most monitoring systems all have ping checks to make sure the remote device is up, but librenms doesnt have that. thats what i was trying to do.
edit: see what youre saying regarding the snmp checks
LibreNMS does a ping check every time the device is polled so you don’t need to use service checks.
As everything runs on a cron then you can (not always) have a delay of around 5 minutes. You can change poller to run every minute instead (see our docs) but you MUST have the hardware to increase with the increased load this places on your install.
As for the device showing as red in the devices list, eventlog will tell you why.
I have no idea where you got this cron setup from but you’ve added poller.php - remove that and your device down issue in the device list will go away.
