Issue with new instalation
Hi, I have an issue with a new librenms instalation, when I add devices they dont show the all the data, but in the old instalation it does.
The output of validate.php shows 2 errors, but I haven`t found any solutions.
./validate.php ?
LibreNMS 22.7.0-46-g36e7a7793
DB Schema 2022_07_19_081224_plugins_unique_index (244)
PHP 8.1.9
Python 3.6.8
Database MariaDB 10.3.32-MariaDB
RRDTool 1.7.0
SNMP 5.8
[OK] Composer Version: 2.3.10
[OK]
[OK] MySQl and PHP time match
[FAIL] No active polling method detected
[FAIL] Python wrapper cron entry is not present
The only difference in the installation is that I change the installation directory from /opt/librenms to /data/librenms
Can you help me out with this, thanks
Old installation
New installation
I just installed on ubuntu 22.04 and the error you put appeared, after adding a host the ./validate.php appears without errors.
I took no action other than a capture on the device I added.
I was able to solve it, there was an error in the cron file, it referred to /opt which is the default installation directory, I changed it to /data which is the directory I used and it was solved
Hi all,
My issue
I have the same issue (FAILS in validation)
but I have a standard installation (I haven’t changed the installation directory) with Ubuntu 22.04.1 LTS.
As you see below I have the same FAILs in my validation:
  • [FAIL] No active polling method detected
  • [FAIL] No python wrapper pollers found
LibreNMS is running since 16 hours, I have one device added manually, I also tried to reboot.
Thank you for your help
Hope this can help somebody else.
Here is my setup:
librenms@**********:~$ ./validate.php
LibreNMS  | 22.7.0-58-g83126161d
DB Schema | 2022_07_19_081224_plugins_unique_index (244)
PHP       | 8.1.8
Python    | 3.10.4
Database  | MariaDB 10.6.7-MariaDB-2ubuntu1.1
SNMP      | 5.9.1
[OK]
[FAIL]  No active polling method detected         <----------------------------
[FAIL]  No python wrapper pollers found           <----------------------------
[OK]    Redis is unavailable
[OK]    rrd_dir is writable
librenms@*********:~$
librenms@*********:~$ vim /etc/cron.d/librenms
# Using this cron file requires an additional user on your system, please see install docs.
33   */6  * * *   librenms    /opt/librenms/cronic /opt/librenms/discovery-wrapper.py 1
*/5  *    * * *   librenms    /opt/librenms/discovery.php -h new >> /dev/null 2>&1
*/5  *    * * *   librenms    /opt/librenms/cronic /opt/librenms/poller-wrapper.py 16
*    *    * * *   librenms    /opt/librenms/alerts.php >> /dev/null 2>&1
*/5  *    * * *   librenms    /opt/librenms/poll-billing.php >> /dev/null 2>&1
01   *    * * *   librenms    /opt/librenms/billing-calculate.php >> /dev/null 2>&1
*/5  *    * * *   librenms    /opt/librenms/check-services.php >> /dev/null 2>&1
*    *    * * *   librenms    cd /opt/librenms/ && php artisan schedule:run >> /dev/null 2>&1
Thank you
Hi all,
I found the cron command was not installed in my Ubuntu.
After the installation of cron after some minutes (more or less 10 min, probably the first use of cron, sorry if I am not precise) the validation is ok.
Hope this can help.
I have this same issue with the python wrapper cron entry not present.
Cron is installed, i did not change directories though
Cron file
Hi community,
I have exactly the same issue, I use the latest docker image of LibreNMS, version 22.8.0.
/opt/librenms $ ./validate.php
LibreNMS  | 22.8.0
PHP       | 8.0.22
Python    | 3.10.5
Database  | MariaDB 10.5.16-MariaDB-1:10.5.16+maria~focal
SNMP      | 5.9.3
[OK]    Installed from the official Docker image; no Composer required
[OK]
[OK]    Redis is functional
[WARN]  IPv6 is disabled on your server, you will not be able to add IPv6 devices.
[WARN]  Updates are managed through the official Docker image
/opt/librenms $
I can add devices in LibreNMS WebUI but they are not polled.
I installed LibreNMS using the official docker compose file :
Kindly please help ! :slightly_smiling_face:
So this on another thread this might help
/opt/librenms/.env
DB_SOCKET=/var/run/mysqld/mysqld.sock
/opt/librenms/config.php
$config[‘db_socket’] = ‘/var/run/mysqld/mysqld.sock’;
Make sure you are on the latest image, there was an issue with some 22.8.0 builds.
