RockyLinux 9.4 (Hyper-V VM), fresh install of LibreNMS
The install and initial setup was relatively smooth however now that I am trying to add devices/hosts I am unable to with the error that it cannot ping.
Web UI validation shows:
INFO: fping FAILURES can be ignored if running LibreNMS in a jail without ::1. You may want to test it manually: fping ::1
FAIL: /usr/sbin/fping could not be executed. /usr/sbin/fping must have CAP_NET_RAW capability (getcap) or suid. Selinux exclusions may be required. (/usr/sbin/fping: cannot bind source address : Permission denied)
FAIL: /usr/sbin/fping should have CAP_NET_RAW!
Fix:
setcap cap_net_raw+ep /usr/sbin/fping
Validation via console shows:
[librenms@LibreNMS-H5 ~]$ ./validate.php
| Component |
Version |
| LibreNMS |
24.5.0-27-g7ac1b3303 (2024-06-05T07:16:33-06:00) |
| DB Schema |
2024_04_29_183605_custom_maps_drop_background_suffix_and_background_version (294) |
| PHP |
8.1.29 |
| Python |
3.9.18 |
| Database |
MariaDB 10.5.22-MariaDB |
| RRDTool |
1.7.2 |
| SNMP |
5.9.1 |
[OK] Composer Version: 2.7.6
[WARN] You have no devices.
Consider adding a device such as localhost: /addhost
[WARN] Your install is over 24 hours out of date, last update: Wed, 05 Jun 2024 13:16:33 +0000
I run: setcap cap_net_raw+ep /usr/sbin/fping
with no errors and it appears to run without problems.
Despite running the apparent ‘fix’ the problem never seems to be resolved. I can manually run fping from console and it exists in the location that LibreNMS is expecting.
Where else can I look or what else can I try?
It’s definitely an SELinux problem. There are deny events in the audit log for fping via http. I’ve set SELinux to permissive temporarily and validation now works without that error as well as adding devices.
have you followed these instructions regarding selinux?
If they do not work please open a PR or reply to use with working policies so we can fix the documentation.
Those were the exact instructions I followed. Here is the output of running them again.
[root@server user]# semanage fcontext -a -t httpd_sys_content_t '/opt/librenms/html(/.)?’
File context for /opt/librenms/html(/.)? already defined, modifying instead
[root@server user]# semanage fcontext -a -t httpd_sys_rw_content_t '/opt/librenms/(rrd|storage)(/.)?’
File context for /opt/librenms/(rrd|storage)(/.)? already defined, modifying instead
[root@server user]# semanage fcontext -a -t httpd_log_t "/opt/librenms/logs(/.)?"
File context for /opt/librenms/logs(/.)? already defined, modifying instead
[root@server user]# semanage fcontext -a -t httpd_cache_t '/opt/librenms/cache(/.)?’
File context for /opt/librenms/cache(/.)? already defined, modifying instead
[root@server user]# semanage fcontext -a -t bin_t ‘/opt/librenms/librenms-service.py’
File context for /opt/librenms/librenms-service.py already defined, modifying instead
[root@server user]# restorecon -RFvv /opt/librenms
Relabeled /opt/librenms/.env from system_u:object_r:httpd_sys_rw_content_t:s0 to system_u:object_r:usr_t:s0
[root@server user]# setsebool -P httpd_can_sendmail=1
[root@server user]# setsebool -P httpd_execmem 1
[root@server user]# chcon -t httpd_sys_rw_content_t /opt/librenms/.env
[root@server user]# checkmodule -M -m -o http_fping.mod http_fping.tt
checkmodule: unable to open http_fping.tt: No such file or directory
[root@server user]# cd /opt
[root@server opt]# checkmodule -M -m -o http_fping.mod http_fping.tt
[root@server opt]# semodule_package -o http_fping.pp -m http_fping.mod
[root@server opt]# semodule -i http_fping.pp
I also rebooted the server and it still doesn’t work without setting SELinux to premissive.
I had the same behavior.
To make fping works with selinux on Rocky 9, I needed to make some changes to http_fping policy:
module http_fping 1.0;
require {
type node_t;
type httpd_t;
class capability net_raw;
class icmp_socket create;
class rawip_socket { getopt create setopt write read bind node_bind};
#============= httpd_t ==============
allow httpd_t node_t:rawip_socket node_bind;
allow httpd_t self:capability net_raw;
allow httpd_t self:icmp_socket create;
allow httpd_t self:rawip_socket { getopt create setopt write read bind};
Underscoredje, what file is this in?
