I seem to be have issues install in the php parts, can you see any reason why?
Add the repo
Run again
Then get this:
Add the repo
Run again
Then get this:
Hi @gonzo
What else is this host doing? It seems like it already has php 5 isntalled, the below will show you if this is the case.
$ rpm -qa | grep php-common
php-common-5.4.16-46.el7.x86_64
If this host is not doing anything else then you should be able to remove php-common, however you should probably work out why it’s their first.
If you are using a VM hosting providor than it may be that their image includes this by default.
Hi, I managed to remove the old PHP and the install was a breeze right until the very last part, can’t see the cause of this issue after spending a while researching:
create config.php
The validate says wats wrong…
Php internal file starts whit <?php yours start whit ###
Seems u didnot do the install correct, the install will make you an config. I think u pasted an other config file wrongly.
