I trying to deploy one more server on distributed polling mode.
I guess that I’m on right way but some times my poller had this log:
This system is already joined as the poller master.
I observed that if I change the “$config[‘distributed_poller_name’]” it back to work.
That variable has to be unique per poller. You don’t need to set it but if you don’t we use the systems hostname so I’m guessing you might have cloned your poller which would explain it.
I cloned the second server from the first and changed the configs, but I fixed the pooler name, take a look:
first:
$config[‘distributed_poller_name’] = ‘LibreNMS’;
$config[‘distributed_poller_group’] = ‘0’;
second:
$config[‘distributed_poller_name’] = ‘LibreNMS-2’;
$config[‘distributed_poller_group’] = ‘1’;
Yeah that’s how it should be.
Ever that i rebooted the second server, I have to rename it again, after rename, it back to work.
Also I deleted the old name on db.
Thats normal?!
I deployed a new serve, everything begin good, but after few times, the same problem:
That makes no sense with that config you have but if the actual vm is renaming itself, fix that first.
I rebuild all servers from zero and everything is working now.
But the graphs don’t working.
When I ran the rrd command on console by root it worked, by user not (ERROR: Could not save png to '/tmp/xxx).
On webui, other error: ERROR: rrdc_flush (device/mempool-cemp-5000.1.rrd) failed with status -1.
Post the output of ./validate.php
Component | Version |
LibreNMS | ebdfbd00d8bc61dbe00fd361278eeb4938f78d19 |
DB Schema | 191 |
PHP | 7.0.19-1~dotdeb+8.1 |
MySQL | 10.0.30-MariaDB-0+deb8u2 |
RRDTool | 1.4.8 |
SNMP | NET-SNMP 5.7.2.1 |
[WARN] Your install is out of date, last update: Mon, 15 May 2017 22:45:02 +0000
Follow my config.php
$config[‘db_host’] = ‘localhost’;
$config[‘db_port’] = ‘3306’;
$config[‘db_user’] = ‘xxxx’;
$config[‘db_pass’] = ‘xxxx’;
$config[‘db_name’] = ‘librenms’;
$config[‘db_socket’] = ‘’;
$config[‘db’][‘extension’] = “mysqli”;// mysql or mysqli
// This is the user LibreNMS will run as
//Please ensure this user is created and has the correct permissions to your install
$config[‘user’] = ‘librenms’;
$config[‘install_dir’] = “/opt/librenms”;
$config[‘base_url’] = “http://librenms.pactual.net”;
#$config[‘rrdcached’] = “unix:/var/run/rrdcached.sock”;
$config[‘snmp’][‘community’] = array(“public”);
$config[‘auth_mechanism’] = “mysql”; # default, other options: ldap, http-auth
#$config[‘http_auth_guest’] = “guest”; # remember to configure this user if you use http-auth
#$config[‘nets’][] = “10.0.0.0/8”;
#$config[‘nets’][] = “172.16.0.0/12”;
#$config[‘nets’][] = “192.168.0.0/16”;
#$config[‘update’] = 0;
$config[‘distributed_poller_name’] = file_get_contents(’/etc/hostname’);
$config[‘distributed_poller_memcached_host’] = “10.21.98.240”; #(selfip)
$config[‘distributed_poller_memcached_port’] = 11211;
$config[‘distributed_poller’] = true;
$config[‘rrdcached’] = “10.21.98.240:42217”; #(selfip)
$config[‘memcached’][‘enable’] = true;
#$config[‘memcached’][‘host’] = “10.21.98.240”;
#$config[‘memcached’][‘port’] = 11211;
$config[‘update’] = 1;
I’m guessing you have rrdcached setup wrong, what’s the start up options?
Please use pastebin or p.libren.ms to post text, it’s unreadable when you just paste it into posts.
Great @laf
After review the rrdcached config, now I can see the graphs for devices polled by default poller group, but devices polled by remotes pollers inst generating graphs.
Need I install rrdcached on remote pollers too?
No but they need access to the rrdcached setup + the ability to create files like over nfs or rrdacached 1.6 (untested)
You are right (as ever).
I using rrdcached 1.5, then I discovery files on defauld poller group, after that I change for the other poller group. everything working fine now
