Issues with ActiveDirectory authentication after pulling Docker image 22.7.0
Hi! I’m having issues with ActiveDirectory authentication when pulling Docker image 22.7.0. Everything is fine with image 22.6.0, so could be a bug related to PHP 8.0
After a login attempt, an error screen appeared which points to librenms.log and found this:
production.ERROR: ldap_get_entries(): Argument #2 ($result) must be of type resource, bool given {“exception”:"[object] (TypeError(code: 0): ldap_get_entries(): Argument #2 ($result) must be of type resource, bool given at /opt/librenms/LibreNMS/Authentication/ActiveDirectoryAuthorizer.php:161)"}
$ ./validate.php
LibreNMS 22.7.0
DB Schema 2022_07_19_081224_plugins_unique_index (243)
PHP 8.0.21
Python 3.10.4
MySQL 10.5.16-MariaDB-1:10.5.16+maria~focal
SNMP 5.9.3
[OK]
[OK] MySQl and PHP time match
I have the same problem,
In the log it sends me the following error
production.ERROR: ldap_get_entries(): Argument #2 ($result) must be of type LDAP\Result, bool given {“exception”:"[object] (TypeError(code: 0): ldap_get_entries(): Argument #2 ( $result) must be of type LDAP\Result, bool given at /opt/librenms/LibreNMS/Authentication/ActiveDirectoryAuthorizer.php:161)"}
Fixed the error thrown (it doesn’t fix your problem tho)
It didn’t work, it keeps showing the same error.
If I go back to php7.4-fpm it works fine but on 8.1 it dies
Help
Also running PHP 8.1 and my Active Directory authentication is no longer working and the logs show exactly the same thing. Had to switch back to mysql to get back in.
LibreNMS  | 22.7.0-67-g55c62b234
DB Schema | 2022_07_03_1947_add_app_data (244)
PHP       | 8.1.2
Python    | 3.10.4
Database  | MariaDB 10.6.7-MariaDB-2ubuntu1.1
SNMP      | 5.9.1
I am having the exact same issue …
Please add
dump($connection, $search, $entries);
On this line ; https://github.com/librenms/librenms/blob/2ef1c3670b5d6c7b0cc894e83347f20619631b11/LibreNMS/Authentication/ActiveDirectoryAuthorizer.php#L169
And post the output, if it doesn’t give you output. Replace dump with dd
