I’m having an issue that I’ve noticed on the aggregate graphs of our Libre instance. For some reason when looking at an aggregate graph, if I set the start date to be 4 months before the current date then the information is wildly inaccurate.
Example images:
These images are both of the same graph, in the first image, the start date is set to 4 months and 1 day before the current date (22nd May 2023). In the second image it is exactly 4 months ago.
This is only happening on aggregate graphs, if I look at the individual graphs used to make up this aggregate then it all looks fine and correct.
Is this a setting that needs changing somewhere or does anybody have a similar experience?
./validate.php output:
LibreNMS | 22.7.0
DB Schema | 2022_07_19_081224_plugins_unique_index (243)
PHP | 7.3.24
Python | 3.6.8
MySQL | 10.5.8-MariaDB-1:10.5.8+maria~buster
RRDTool | 1.4.8
SNMP | 5.7.2
[OK] Composer Version: 2.5.5
[OK]
[OK] MySQl and PHP time match
[FAIL] We have found some files that are owned by a different user than 'librenms', this will stop you updating automatically and / or rrd files being updated causing graphs to fail.
The custom files are weathermap files which should have no impact on a graph.
Any help appreciated.
