Hi LibreNMS Community!
I’m running into an issue with LibreNMS and our Eaton ePDU G3 Metered Input.
By default there’s no graph concerning the voltage or the current, only the Outlets are showing but with empty values (that’s normal because “Metered Input”), but not the input stats. see below:
I was able to get around the issue using custom OIDs, but I would really like to use the “native” graphs.
Any ideas?
Thanks a lot!
