Hi all,
I’m having some issues with the new PagerDuty transport. Specifically how it formats the alerts. The old transport used to set the description of the alert to the actual title of the alert making it easy to figure out what the alert was for. The new transport is setting the description to output the fault which doesn’t really say what happened.
For example, old:
"client": "LibreNMS",
"description": "Port utilisation over threshold on <hostname>",
"event_type": "trigger",
"incident_key": "21339",
"service_key": "<snip>",
"details": [
"port_id = 515018; ifDescr = irb.1314; "
New (port down alert):
"description": "sysObjectID = .1.3.6.1.4.1.2636.1.1.1.2.134; sysDescr = Juniper Networks, Inc. srx320 internet router, kernel JUNOS 15.1X49-D60.7, Build date: 2016-09-13 23:25:07 UTC Copyright (c) 1996-2016 Juniper Networks, Inc.; port_id = 518097; ifDescr = vlan; ",
"incident_key": "21883",
I thought initially this might be because our alert templates are coded in HTML, so I tried setting this before the HTML section, but that didn’t seem to fix.
@if ($alert->transport == pagerduty)
{{ $alert->title }}
Severity: {{ $alert->severity }}
@if ($alert->state == 0) Time elapsed: {{ $alert->elapsed }} @endif
Unique-ID: {{ $alert->uid }}
Rule: @if ($alert->name) {{ $alert->name }} @else {{ $alert->rule }} @endif
@if ($alert->faults) Faults:
{{ $key }}: {{ $value['string'] }}
@endforeach
@endif
@else
Anyone have any ideas?
Thanks!
