I see,
according the output below the NMS cannot get some OIDs due to missing of the MIB file ?
LibreNMS Version: 46616c13927577d2408a2df31fadb325f6e92045
DB Schema: 148
PHP: 7.0.11
MySQL: 5.5.50-MariaDB
RRDTool: 1.4.8
SNMP: NET-SNMP 5.7.2
[WARN] You don’t have $config[“user”] set, this most likely needs to be set to librenms
[FAIL] You have no timezone set for php: http://php.net/manual/en/datetime.configuration.php#ini.date.timezone
[[email protected] librenms]# ./poller.php -h 3000a.bdy01.pas01.radio -r -f -d -m os
Southland Communications Poller
Version info:
Commit SHA: 46616c13927577d2408a2df31fadb325f6e92045
Commit Date: 1476993241
DB Schema: 148
PHP: 7.0.11
RRDTool: 1.4.8
DEBUG!
Starting polling run:
SQL[SELECT device_id
FROM devices
WHERE disabled
= 0 AND hostname
= ‘3000a.bdy01.pas01.radio’ ORDER BY device_id
ASC]
Hostname: 3000a.bdy01.pas01.radio
Device ID: 33
OS: dragonwavec
SNMP[/usr/bin/snmpget -v2c -c COMMUNITY -Oqv -m SNMPv2-MIB -M /opt/librenms/mibs udp:HOSTNAME:161 sysObjectID.0]
SNMPv2-SMI::enterprises.7262.2.2
SNMP[/usr/bin/snmpget -v2c -c COMMUNITY -OQnUst -m SNMPv2-MIB:HOST-RESOURCES-MIB:SNMP-FRAMEWORK-MIB -M /opt/librenms/mibs udp:HOSTNAME:161 sysUpTime.0 sysLocation.0 sysContact.0 sysName.0 sysObjectID.0]
sysUpTime.0 = 2440531201
sysLocation.0 = Bradley PCN/RSL -36.5 Typ -36.2
sysContact.0 =
sysName.0 = Pasadena to Bradley #3 H Dish #2
sysObjectID.0 = enterprises.7262.2.2
SNMP[/usr/bin/snmpget -v2c -c COMMUNITY -OvQ -m SNMPv2-MIB:HOST-RESOURCES-MIB:SNMP-FRAMEWORK-MIB -M /opt/librenms/mibs udp:HOSTNAME:161 sysDescr.0]
hc50_322_256qam Omni: 1.04.08
SNMP[/usr/bin/snmpget -v2c -c COMMUNITY -OQnUst -m HOST-RESOURCES-MIB:SNMP-FRAMEWORK-MIB -M /opt/librenms/mibs udp:HOSTNAME:161 snmpEngineTime.0 hrSystemUptime.0]
snmpEngineTime.0 = 16713378
hrSystemUptime.0 = No Such Object available on this agent at this OID
Using SNMP Agent Uptime (24405312s)
RRD[update /opt/librenms/rrd/3000a.bdy01.pas01.radio/uptime.rrd N:24405312]
[RRD Disabled]Uptime: 282 days, 11h 15m 12s
Using cached lat/lng from other device
Load poller module os
SNMP[/usr/bin/snmpget -v2c -c COMMUNITY -OQv udp:HOSTNAME:161 HORIZON-ODU-MIB::hzOduUnitSerialNo.0]
MIB search path: /root/.snmp/mibs:/usr/share/snmp/mibs
Cannot find module (HORIZON-ODU-MIB): At line 0 in (none)
HORIZON-ODU-MIB::hzOduUnitSerialNo.0: Unknown Object Identifier
SNMP[/usr/bin/snmpget -v2c -c COMMUNITY -OQv udp:HOSTNAME:161 SNMPv2-MIB::sysLocation.0]
SNMP[/usr/bin/snmpget -v2c -c COMMUNITY -OQv udp:HOSTNAME:161 HORIZON-ODU-MIB::hzOduSystemLicensedSpeed.0]
HORIZON-ODU-MIB::hzOduSystemLicensedSpeed.0: Unknown Object Identifier
SNMP[/usr/bin/snmpget -v2c -c COMMUNITY -OQv udp:HOSTNAME:161 SNMPv2-MIB::sysDescr.0]
SNMP[/usr/bin/snmpget -v2c -c COMMUNITY -OQv udp:HOSTNAME:161 HORIZON-ODU-MIB::hzOduModem1ChannelizedRslBelowThresholdParameters.0]
HORIZON-ODU-MIB::hzOduModem1ChannelizedRslBelowThresholdParameters.0: Unknown Object Identifier
SNMP[/usr/bin/snmpget -v2c -c COMMUNITY -OQv udp:HOSTNAME:161 HORIZON-ODU-MIB::hzOduIpAddress.0]
HORIZON-ODU-MIB::hzOduIpAddress.0: Unknown Object Identifier
Hardware:
Version: 1.04.08
Features: WEB: Bradley PCN/RSL -36.5 Typ -36.2 SPEED: Mbit MODE: hc50_322_256qam THRESHOLD: dBm
Serial:
Runtime for poller module ‘os’: 0.11609601974487 seconds
Unload poller module os
RRD[update /opt/librenms/rrd/3000a.bdy01.pas01.radio/poller-perf-os.rrd N:0.11609601974487]
[RRD Disabled]### Start Device Groups ###
SQL[SELECT DISTINCT(devices.device_id) FROM devices WHERE devices.device_id=‘33’ AND (devices.status = “down” ) LIMIT 1]
SQL[SELECT DISTINCT(alerts.device_id) FROM alerts WHERE alerts.device_id=‘33’ AND (alerts.rule_id = “10” && alerts.state = “1” ) LIMIT 1]
SQL[SELECT DISTINCT(alerts.device_id) FROM alerts WHERE alerts.device_id=‘33’ AND (alerts.rule_id = “7” && alerts.state = “1” ) LIMIT 1]
SQL[SELECT device_group_id
FROM device_group_device
WHERE device_id
=‘33’]
Groups Added:
Groups Removed:
End Device Groups
RRD[update /opt/librenms/rrd/3000a.bdy01.pas01.radio/poller-perf.rrd N:3.293]
[RRD Disabled]Polled in 3.293 seconds
Updating 3000a.bdy01.pas01.radio
SQL[UPDATE devices
set uptime
=‘24405312’,last_polled
=NOW(),last_polled_timetaken
=‘3.293’ WHERE device_id
= ‘33’]
UPDATED!
Start Alerts
WHERE device_id
=‘33’]
SQL[SELECT alert_schedule.schedule_id FROM alert_schedule LEFT JOIN alert_schedule_items ON alert_schedule.schedule_id=alert_schedule_items.schedule_id WHERE ( alert_schedule_items.target = ‘33’ ) && NOW() BETWEEN alert_schedule.start AND alert_schedule.end LIMIT 1]
WHERE device_id
=‘33’]
Rule #1 (Device Unreachable):
SQL[SELECT * FROM devices WHERE (devices.device_id = ‘33’) && ( ( ( devices.status = 0 && ( ( devices.disabled = 0 && devices.ignore = 0 ) ) ) ) = “1” )]
Status: NOCHG
Rule #2 (Device rebooted):
SQL[SELECT * FROM devices WHERE (devices.device_id = ‘33’) && (devices.uptime < “300” && ( ( devices.disabled = 0 && devices.ignore = 0 ) ) = “1” )]
Status: NOCHG
Rule #3 (BGP Session down):
SQL[SELECT * FROM bgpPeers,devices WHERE (( devices.device_id = bgpPeers.device_id ) && bgpPeers.device_id = ‘33’) && (bgpPeers.bgpPeerState != “established” && ( ( devices.status = 1 && ( ( devices.disabled = 0 && devices.ignore = 0 ) ) ) ) = “1” )]
Status: NOCHG
Rule #4 (BGP Session establised):
SQL[SELECT * FROM bgpPeers WHERE (bgpPeers.device_id = ‘33’) && (bgpPeers.bgpPeerFsmEstablishedTime < “300” && bgpPeers.bgpPeerState = “established” )]
Status: NOCHG
Rule #7 (Wireless Link Down):
SQL[SELECT * FROM sensors,devices WHERE (( devices.device_id = sensors.device_id ) && sensors.device_id = ‘33’) && (sensors.sensor_current > sensors.sensor_limit && devices.type = “Wireless” && sensors.sensor_index = “WirelessLink” )]
Status: NOCHG
End Alerts
SQL[INSERT INTO perf_times
(type
,doing
,start
,duration
,devices
,poller
) VALUES (‘poll’,‘3000a.bdy01.pas01.radio’,‘1477031137.7362’,‘3.316’,‘1’,‘nms.southlandcommunications.com\n’)]
./poller.php 3000a.bdy01.pas01.radio 2016-10-21 06:25:41 - 1 devices polled in 3.316 secs
MySQL: Cell[4/0s] Row[4/0s] Rows[8/0s] Column[3/0s] Update[1/0s] Insert[1/0s] Delete[0/0s]
