It seems that RRDTune may cause the graph to be blank
I enabled global RRDTune and changed the ifSpeed of an interface to 100M. I noticed that when the traffic exceeds 100M, the traffic graph displays as blank. Could this be affected by the global RRDTune?
Yes, if the port can handle more than 100M then you need to tune the port to it’s physical limit not what you may want to limit your client or the port itself too.
Understood, Thank you for your answer.
