Hello everyone , need help for fixed my device juniper srx 1500 cannot detected temperature in librenms .
It works fine with SRX340. What have you tried?
yeah sir , I have tried all the methods, from the config comparison on the router and on the librenms side . no have idea , i think issue at sensor temperature in router but i try with solarwind the router showing temperature . please help me
I have no idea what you are doing. Librenms doesn’t do anything with config; that’s oxidized. Oxidized has nothing to do with monitoring temperature.
then I need more than
this image is my device router ipt this same type srx 1500 but detected temperature , after compare both device not have issue with config in device
So you have 2 SRX1500’s and one does show the temperature in LibreNMS and one doesn’t? I doubt the problem lies within LibreNMS then?
do you have any suggestions with that issues sir ,
yes correct
If same software revision then ask JTAC?
Run a discovery on both and compare the output and see which one is getting a response from snmpwalk and which one is not?
librenms@ao-librenms:~$ ./discovery.php -h 11
LibreNMS Discovery
ROUTER-IPT-JKT 11 junos
#### Load disco module core ####
OS: Juniper JunOS (junos)
>> Runtime for discovery module 'core': 0.4020 seconds with 2819984 bytes
>> SNMP: [1/0.04s] MySQL: [0/0.00s] RRD: [0/0.00s]
#### Unload disco module core ####
#### Load disco module os ####
Hardware: Juniper SRX1500 Internet Router
OS Version: 20.2R3.9
OS Features:
Serial: DB0820AK0222
>> Runtime for discovery module 'os': 0.1390 seconds with 327216 bytes
>> SNMP: [4/0.12s] MySQL: [0/0.00s] RRD: [0/0.00s]
#### Unload disco module os ####
#### Load disco module ports ####
.X.................................................................
>> Runtime for discovery module 'ports': 0.3580 seconds with 64648 bytes
>> SNMP: [5/0.29s] MySQL: [67/0.39s] RRD: [0/0.00s]
#### Unload disco module ports ####
#### Load disco module ports-stack ####
>> Runtime for discovery module 'ports-stack': 0.0950 seconds with 472 bytes
>> SNMP: [0/0.00s] MySQL: [1/0.01s] RRD: [0/0.00s]
#### Unload disco module ports-stack ####
Module [ xdsl ] disabled globally.
#### Load disco module entity-physical ####
Caching OIDs: jnxBoxAnatomy............
>> Runtime for discovery module 'entity-physical': 6.4200 seconds with 83856 bytes
>> SNMP: [1/6.38s] MySQL: [25/0.13s] RRD: [0/0.00s]
#### Unload disco module entity-physical ####
Module [ entity-state ] disabled globally.
Module [ isis ] disabled globally.
#### Load disco module processors ####
Pre-cache junos: JnxDomCurrentEntry JnxDomCurrentLaneEntry jnxoptIfOTNPMFECCurrentTableJnxoptIfOTNPMFECCurrentEntry
Caching data: mempools processors sensors
>> Runtime for discovery module 'processors': 12.3600 seconds with 604456 bytes
>> SNMP: [18/12.34s] MySQL: [8/0.05s] RRD: [0/0.00s]
#### Unload disco module processors ####
#### Load disco module mempools ####
ssssssssssssssssssssssssssssssssssssssssssssssssssssssssssssssssssssssssssssssssssssssssssssss...
junos [system]: FPC: FEB @ 0/*/*: 63% 1.26 GiB / 2 GiB
junos [system]: Routing Engine: 75% 1.39 GiB / 1.86 GiB
junos [system]: Single SPU 0/0: 53%
>> Runtime for discovery module 'mempools': 0.2580 seconds with 344808 bytes
>> SNMP: [2/0.24s] MySQL: [4/0.03s] RRD: [0/0.00s]
#### Unload disco module mempools ####
#### Load disco module cisco-vrf-lite ####
>> Runtime for discovery module 'cisco-vrf-lite': 0.0010 seconds with 1584 bytes
#### Unload disco module cisco-vrf-lite ####
Module [ cisco-mac-accounting ] disabled globally.
Module [ cisco-pw ] disabled globally.
#### Load disco module vrf ####
>> Runtime for discovery module 'vrf': 21.8800 seconds with 5968 bytes
>> SNMP: [4/21.88s] MySQL: [2/0.05s] RRD: [0/0.00s]
#### Unload disco module vrf ####
Module [ cisco-cef ] disabled globally.
#### Load disco module slas ####
>> Runtime for discovery module 'slas': 6.0440 seconds with 33912 bytes
#### Unload disco module slas ####
Module [ cisco-cbqos ] disabled globally.
Module [ cisco-otv ] disabled globally.
Module [ cisco-qfp ] disabled globally.
#### Load disco module ipv4-addresses ####
s.s.s.s.s.s.s.s.s.s.s.s.s.s.s.
>> Runtime for discovery module 'ipv4-addresses': 0.6850 seconds with 38296 bytes
>> SNMP: [16/0.60s] MySQL: [107/0.66s] RRD: [0/0.00s]
#### Unload disco module ipv4-addresses ####
#### Load disco module ipv6-addresses ####
>> Runtime for discovery module 'ipv6-addresses': 6.0800 seconds with 3088 bytes
>> SNMP: [2/6.08s] MySQL: [1/0.01s] RRD: [0/0.00s]
#### Unload disco module ipv6-addresses ####
Module [ route ] disabled globally.
#### Load disco module sensors ####
ENTITY-SENSOR: Caching OIDs: entPhysicalDescr
Airflow:
Current: JunOS ..
Charge:
Dbm: JunOS ....
Fanspeed:
Frequency:
Humidity:
Load:
Loss:
Power:
Power_consumed:
Power_factor:
Runtime:
Signal:
State: Cur 2, Low: null, Low Warn: null, Warn: null, High: null
.Cur 2, Low: null, Low Warn: null, Warn: null, High: null
.Cur 6, Low: null, Low Warn: null, Warn: null, High: null
Count: Cur 30343, Low: null, Low Warn: null, Warn: null, High: 2097152
Temperature: JunOS ....
Tv_signal:
Bitrate:
Voltage:
Snr:
Pressure:
Cooling:
Delay:
Quality_factor:
Chromatic_dispersion:
Ber: JunOS
Eer:
Waterflow:
Percent:
>> Runtime for discovery module 'sensors': 1.0640 seconds with 125544 bytes
>> SNMP: [26/0.92s] MySQL: [149/0.97s] RRD: [0/0.00s]
#### Unload disco module sensors ####
#### Load disco module storage ####
aix_filesystem : hrStorage : ................
>> Runtime for discovery module 'storage': 1.5410 seconds with 175536 bytes
>> SNMP: [5/0.18s] MySQL: [36/0.20s] RRD: [0/0.00s]
#### Unload disco module storage ####
#### Load disco module hr-device ####
>> Runtime for discovery module 'hr-device': 0.0760 seconds with 2776 bytes
>> SNMP: [2/0.08s] MySQL: [1/0.01s] RRD: [0/0.00s]
#### Unload disco module hr-device ####
#### Load disco module discovery-protocols ####
CISCO-CDP-MIB:
LLDP-MIB: .
OSPF Discovery:
>> Runtime for discovery module 'discovery-protocols': 0.2550 seconds with 437272 bytes
>> SNMP: [1/0.05s] MySQL: [13/0.18s] RRD: [0/0.00s]
#### Unload disco module discovery-protocols ####
#### Load disco module arp-table ####
fxp0.0:
em0.0:
em1.32768:
ge-0/0/0.618:
ge-0/0/0.619:
ge-0/0/2.0:
ge-0/0/3.0:
ge-0/0/5.0:
ge-0/0/6.0:
ae0.0:
>> Runtime for discovery module 'arp-table': 0.1690 seconds with 128504 bytes
>> SNMP: [2/0.13s] MySQL: [12/0.17s] RRD: [0/0.00s]
#### Unload disco module arp-table ####
Module [ discovery-arp ] disabled globally.
Module [ junose-atm-vp ] disabled globally.
Module [ bgp-peers ] disabled on host.
#### Load disco module vlans ####
JUNIPER-VLAN-MIB VLANs: ver version1 +.
>> Runtime for discovery module 'vlans': 0.6440 seconds with 12632 bytes
>> SNMP: [9/0.64s] MySQL: [2/0.02s] RRD: [0/0.00s]
#### Unload disco module vlans ####
Module [ vmware-vminfo ] disabled globally.
Module [ libvirt-vminfo ] disabled globally.
Module [ printer-supplies ] disabled globally.
#### Load disco module ucd-diskio ####
>> Runtime for discovery module 'ucd-diskio': 0.0350 seconds with 1368 bytes
>> SNMP: [1/0.03s] MySQL: [1/0.01s] RRD: [0/0.00s]
#### Unload disco module ucd-diskio ####
Module [ applications ] disabled globally.
#### Load disco module services ####
>> Runtime for discovery module 'services': 0.0000 seconds with 688 bytes
>> SNMP: [0/0.00s] MySQL: [0/0.00s] RRD: [0/0.00s]
#### Unload disco module services ####
#### Load disco module stp ####
Instances:
Ports:
>> Runtime for discovery module 'stp': 0.0370 seconds with 60464 bytes
>> SNMP: [1/0.03s] MySQL: [2/0.01s] RRD: [0/0.00s]
#### Unload disco module stp ####
#### Load disco module ntp ####
>> Runtime for discovery module 'ntp': 0.0000 seconds with 232 bytes
#### Unload disco module ntp ####
Module [ loadbalancers ] disabled globally.
Module [ mef ] disabled globally.
#### Load disco module wireless ####
>> Runtime for discovery module 'wireless': 0.0180 seconds with 128312 bytes
>> SNMP: [0/0.00s] MySQL: [24/0.11s] RRD: [0/0.00s]
#### Unload disco module wireless ####
#### Load disco module fdb-table ####
>> Runtime for discovery module 'fdb-table': 0.0960 seconds with 2080 bytes
>> SNMP: [0/0.00s] MySQL: [2/0.01s] RRD: [0/0.00s]
#### Unload disco module fdb-table ####
#### Load disco module mpls ####
>> Runtime for discovery module 'mpls': 0.0010 seconds with 34952 bytes
#### Unload disco module mpls ####
Discovered in 59.791 seconds
SNMP [101/50.06s]: Snmpget[47/1.68s] Snmpwalk[54/48.37s]
SQL [464/3.09s]: Select[321/2.28s] Update[125/0.66s] Delete[3/0.07s] Insert[15/0.07s]
RRD [0/0.00s]:
this device have temperature
librenms@ao-librenms:~$ ./discovery.php -h 57
LibreNMS Discovery
router-b2b-jkt 57 junos
>> Runtime for discovery module 'core': 0.3820 seconds with 2819984 bytes
>> SNMP: [1/0.06s] MySQL: [0/0.00s] RRD: [0/0.00s]
OS Version: 15.1X49-D60.7
OS Features:
Serial: DB2419AK0044
>> Runtime for discovery module 'os': 0.1130 seconds with 325936 bytes
>> SNMP: [4/0.10s] MySQL: [0/0.00s] RRD: [0/0.00s]
.X................................................................................
>> Runtime for discovery module 'ports': 0.3930 seconds with 70568 bytes
>> SNMP: [5/0.33s] MySQL: [82/0.34s] RRD: [0/0.00s]
>> Runtime for discovery module 'ports-stack': 0.0980 seconds with 464 bytes
>> Runtime for discovery module 'entity-physical': 0.2510 seconds with 39808 bytes
>> SNMP: [1/0.22s] MySQL: [13/0.10s] RRD: [0/0.00s]
>> Runtime for discovery module 'processors': 1.4280 seconds with 329088 bytes
>> SNMP: [18/1.41s] MySQL: [6/0.03s] RRD: [0/0.00s]
sssssssssssssssssssssssssssssssssssssssssU.
junos [system]: Routing Engine: 40% 781.6 MiB / 1.91 GiB
junos [system]: Single SPU 0/0: 19%
>> Runtime for discovery module 'mempools': 0.1560 seconds with 345032 bytes
>> SNMP: [2/0.14s] MySQL: [5/0.04s] RRD: [0/0.00s]
>> Runtime for discovery module 'cisco-vrf-lite': 0.0010 seconds with 1672 bytes
>> Runtime for discovery module 'vrf': 0.2230 seconds with 5048 bytes
>> SNMP: [4/0.22s] MySQL: [2/0.03s] RRD: [0/0.00s]
>> Runtime for discovery module 'slas': 0.2430 seconds with 34320 bytes
s.s.s.s.s.s.s.s.s.s.s.s.s.s.s.s.s.s.s.s.s.s.s.s.s.
>> Runtime for discovery module 'ipv4-addresses': 1.1440 seconds with 39456 bytes
>> SNMP: [26/0.99s] MySQL: [177/1.06s] RRD: [0/0.00s]
>> Runtime for discovery module 'ipv6-addresses': 0.3150 seconds with 2896 bytes
>> SNMP: [2/0.31s] MySQL: [1/0.02s] RRD: [0/0.00s]
Airflow:
Current: JunOS
Charge:
Dbm: JunOS
Fanspeed:
Frequency:
Humidity:
Load:
Loss:
Power:
Power_consumed:
Power_factor:
Runtime:
Signal:
Count: Cur 9825, Low: null, Low Warn: null, Warn: null, High: 2097152
Temperature: JunOS
Tv_signal:
Bitrate:
Voltage:
Snr:
Pressure:
Cooling:
Delay:
Quality_factor:
Ber: JunOS
Eer:
Waterflow:
Percent:
>> Runtime for discovery module 'sensors': 0.5580 seconds with 70064 bytes
>> SNMP: [14/0.47s] MySQL: [78/0.55s] RRD: [0/0.00s]
>> Runtime for discovery module 'storage': 0.7010 seconds with 63352 bytes
>> SNMP: [5/0.18s] MySQL: [20/0.12s] RRD: [0/0.00s]
>> Runtime for discovery module 'hr-device': 0.0840 seconds with 2400 bytes
CISCO-CDP-MIB:
LLDP-MIB:
OSPF Discovery: i
>> Runtime for discovery module 'discovery-protocols': 0.1020 seconds with 4112 bytes
>> SNMP: [0/0.00s] MySQL: [3/0.04s] RRD: [0/0.00s]
fxp0.0:
em0.0:
em1.32768:
ge-0/0/0.0:
ge-0/0/1.0:
ge-0/0/2.0:
xe-0/0/16.0:
ge-0/0/10.0:
ge-0/0/4.0:
ge-0/0/5.3411:
ge-0/0/5.3845:
ge-0/0/6.0:
ge-0/0/7.0:
ge-0/0/8.0:
ae0.2021:
ge-0/0/9.0:
ge-0/0/11.10:
ge-0/0/11.11:
ae1.0:
>> Runtime for discovery module 'arp-table': 0.1320 seconds with 196304 bytes
>> SNMP: [2/0.10s] MySQL: [21/0.25s] RRD: [0/0.00s]
#### Load disco module bgp-peers ####
AS65505 ......
>> Runtime for discovery module 'bgp-peers': 0.2480 seconds with 50112 bytes
>> SNMP: [4/0.22s] MySQL: [32/0.18s] RRD: [0/0.00s]
#### Unload disco module bgp-peers ####
>> Runtime for discovery module 'vlans': 0.5120 seconds with 12792 bytes
>> SNMP: [9/0.51s] MySQL: [2/0.02s] RRD: [0/0.00s]
>> Runtime for discovery module 'ucd-diskio': 0.0390 seconds with 1376 bytes
>> SNMP: [1/0.04s] MySQL: [1/0.01s] RRD: [0/0.00s]
Instances:
Ports:
>> Runtime for discovery module 'stp': 0.0400 seconds with 65936 bytes
>> SNMP: [1/0.03s] MySQL: [2/0.02s] RRD: [0/0.00s]
>> Runtime for discovery module 'wireless': 0.0190 seconds with 194296 bytes
>> SNMP: [0/0.00s] MySQL: [24/0.12s] RRD: [0/0.00s]
>> Runtime for discovery module 'fdb-table': 0.1030 seconds with 2080 bytes
Discovered in 8.401 seconds
SNMP [102/5.43s]: Snmpget[45/1.60s] Snmpwalk[56/3.80s] Snmpgetnext[1/0.03s]
SQL [480/3.03s]: Select[315/2.23s] Update[153/0.68s] Delete[5/0.08s] Insert[7/0.04s]
RRD [0/0.00s]:
this device not have temperature
vs
Time to upgrade?
