We’re having trouble with our Juniper VLANS not updating in LibreNMS. After initially adding the device it pulls all the correct data/vlans. Once you make a change a port to a new vlan the data is never updated in LibreNMS.
Our HP 2920’s do update properly so seems to only be Junipers.
I’ve also setup a clean instance of LibreNMS and the issue persists.
Here is the discovery for the Juniper: https://p.libren.ms/view/3a3f13a3
./poller.php -h 163.41.64.3 -r -f -d | ./pbin.sh : https://p.libren.ms/view/0308443c
Let me know if there is anything else you may need. Thanks
- We use Juniper EX3400
- This happens for single switches and ones in virtual chassis
- Tried updating to JunOS 21.4R3.15 and issue persists Currently on 20.4R3.8
librenms@librenms:~$ /opt/librenms/validate.php
LibreNMS | 23.7.0 (2023-07-16T21:42:41-07:00)
DB Schema | 2023_04_27_164904_update_slas_opstatus_tinyint (252)
PHP | 8.1.2-1ubuntu2.13
Python | 3.10.6
Database | MariaDB 10.6.12-MariaDB-0ubuntu0.22.04.1
RRDTool | 1.7.2
SNMP | 5.9.1
[OK] Composer Version: 2.5.5
[OK] MySQl and PHP time match
