Hi All
Is there any limitation on number of remote poller servers ?
I would like to install 500+ remote pollers (each remote server shall monitor 10-20 devices).
Can single central server can managed so many remote pollers ?
Best regards
Hi All
Best regards
did you look at the doc? http://docs.librenms.org/Extensions/Distributed-Poller/
http://docs.librenms.org/Support/Example-Hardware-Setup/
I don’t think anyone has tested to that scale. I don’t see why it wouldn’t work but you’ll be the first to try.
Thank you …
