Latency graphs not showing for new ping-only devices
I’m having issues adding new ping-only devices - the devices are added just fine, and everything works apart from the latency graphs. These two files do not get created and the web UI shows an error:
ping-perf.rrd
icmp-perf.rrd
This only affects new devices. My pre-existing ping-only devices are working fine, graphs and all.
I don’t know when this problem was introduced - I haven’t added a ping-only device for a long time before today. I did notice this recent change in the github log though, and thought it might be related.
I can reproduce this easily, by simply adding a new ping-only device to any reachable address, e.g. 1.1.1.1.
Example output from lnms device:poll with option -vvv:
RRD[create /opt/librenms/rrd/1.1.1.1/icmp-perf.rrd --step 300 --source /opt/librenms/rrd/1.1.1.1/ping-perf.rrd DS:avg=ping[1]:GAUGE:600:0:65535 DS:xmt:GAUGE:600:0:65535 DS:rcv:GAUGE:600:0:65535 DS:min:GAUGE:600:0:65535 DS:max:GAUGE:600:0:65535   RRA:AVERAGE:0.5:1:2016 RRA:AVERAGE:0.5:6:1440 RRA:AVERAGE:0.5:24:1440 RRA:AVERAGE:0.5:288:1440 RRA:MIN:0.5:1:2016 RRA:MIN:0.5:6:1440 RRA:MIN:0.5:24:1440 RRA:MIN:0.5:288:1440 RRA:MAX:0.5:1:2016 RRA:MAX:0.5:6:1440 RRA:MAX:0.5:24:1440 RRA:MAX:0.5:288:1440 RRA:LAST:0.5:1:2016  -O]
RRDtool Output: ERROR: error checking for source RRD /opt/librenms/rrd/1.1.1.1/ping-perf.rrd: No such file or directory
RRD[update /opt/librenms/rrd/1.1.1.1/icmp-perf.rrd N:8.83:3:3:8.79:8.88]
RRDtool Output: ERROR: opening '/opt/librenms/rrd/1.1.1.1/icmp-perf.rrd': No such file or directory
Output from validate.php:
LibreNMS  | 24.3.0-26-g36d14480f (2024-04-19T16:22:06+01:00)
DB Schema | 2024_04_10_093513_remove_device_perf (291)
PHP       | 8.1.11
Python    | 3.7.3
Database  | MariaDB 10.3.36-MariaDB-0+deb10u2
RRDTool   | 1.7.1
SNMP      | 5.7.3
[OK]    Composer Version: 2.7.2
[OK]    Redis is unavailable
[OK]    rrd_dir is writable
Looks like it is trying to migrate data from ping-perf.rrd even when it doesn’t exist.
Needs a bug fix.
Yep, that fixed it. Thanks!
This fix doesn’t work where rrdcached is being used, it’s checking the existence of a local file.
Despite the file not existing, it still errors
RRD[last 8.8.8.8/icmp-perf.rrd  --daemon 172.24.200.5:42217]
ERROR: [email protected]:42217: RRD Error: opening '/data/librenms/rrd/8.8.8.8/icmp-perf.rrd': No such file or directory
RRD[last 8.8.8.8/ping-perf.rrd  --daemon 172.24.200.5:42217]
RRD[create 8.8.8.8/icmp-perf.rrd --step 300 --source 8.8.8.8/ping-perf.rrd DS:avg=ping[1]:GAUGE:600:0:65535 DS:xmt:GAUGE:600:0:65535 DS:rcv:GAUGE:600:0
O --daemon 172.24.200.5:42217]
RRDtool Output: RRD[update 8.8.8.8/icmp-perf.rrd N:1.71:6:6:1.66:1.9 --daemon 172.24.200.5:42217]
RRDtool Output: ERROR: error checking for source RRD 8.8.8.8/ping-perf.rrd: No such file or directory
RRDtool Output: ERROR: [email protected]:42217: No such file: /data/librenms/rrd/8.8.8.8/icmp-perf.rrd
I noticed that, the only solution I have for now is to disable data migration when the poller doesn’t have direct file access.
Would it be advisable to generate bulk rrd migration commands to run manually on the rrdcached server?
As it stands, the latest major changes to ping graphing have completely broken all installs using rrdcached. Migration isn’t happening, polled data is being lost and ping graphs aren’t displaying because icmp-perf.rrd is never getting created.
I also have the problem even after the fix was applied. Attaching a screenshot if that will help.
I tried to add a new device to be monitored with ping only and in the overview page where ICMP graph should be, it shows this error:
Error Drawing Graph: ERROR: unknown option ‘–left-axis-format’
So it seems the bug is still affecting devices that were being monitored before and newly added devices.
I second this request.
Any idea if this can be fixed?
I had the same problem, but after ugrading rrdtool it was fixed.
Which version of rrdtool do you have? If you are running Red Hat/CentOS/Linux 7 then it would be 1.4.8. Upgrade to a higher version like 1.7 or 1.8 and it should be fixed after the poller has run.
I was/am running the latest version of rrdtool (1.8.0) and rrdcached.
In order to get mine fixed, I had to shutdown rrdcached, copy all the rrd files locally to librenms, run librenms for a few polling cycles, and then shut everything down again and put the files back with rrdcached. A real pain, but it works.
Here is a script written by @pjchilds on Discord to manually migrate the RRD files.
cd /your/storage/rrd
find . -type f -name ping-perf.rrd -print0 | while IFS= read -r -d '' file; do
    dir=$(dirname "$file")
    rrdtool create "$dir/icmp-perf.rrd" --step 300 --source "$file" \
        DS:avg=ping[1]:GAUGE:600:0:65535 DS:xmt:GAUGE:600:0:65535 \
        DS:rcv:GAUGE:600:0:65535 DS:min:GAUGE:600:0:65535 DS:max:GAUGE:600:0:65535 \
        RRA:AVERAGE:0.5:1:2016 RRA:AVERAGE:0.5:6:1440 RRA:AVERAGE:0.5:24:1440 RRA:AVERAGE:0.5:288:1440 \
        RRA:MIN:0.5:1:2016 RRA:MIN:0.5:6:1440 RRA:MIN:0.5:24:1440 RRA:MIN:0.5:288:1440 \
        RRA:MAX:0.5:1:2016 RRA:MAX:0.5:6:1440 RRA:MAX:0.5:24:1440 RRA:MAX:0.5:288:1440 \
    chown rrdcached:rrdcached "$dir/icmp-perf.rrd"
done
