Hello, does anyone have a working JumpCloud (LDAPS) configuration? This is a completely fresh installation of LibreNMS for the purpose of testing LDAPS integration. I cannot get it to work, depending on my config.php file I get either a No such attribute error or a No such object error.
Here is the output of my daily.sh and validate.php
[root@testbed librenms]# ./daily.sh
Updating Composer packages OK
Updating SQL-Schema OK
Updating submodules OK
Cleaning up DB OK
Fetching notifications OK
Caching PeeringDB data OK
[root@testbed librenms]# ./validate.php
LibreNMS | 1.47-87-g45e0e5e
DB Schema | 1000
PHP | 7.2.14
MySQL | 5.5.60-MariaDB
RRDTool | 1.4.8
SNMP | NET-SNMP 5.7.2
[OK] Composer Version: 1.8.0
[WARN] You have not added any devices yet.
You can add a device in the webui or with ./addhost.php
Here is the configuration that generates the No such attribute error.
## JumpCloud Authentication
$config['auth_mechanism'] = 'ldap';
$config['auth_ldap_port'] = 636;
$config['auth_ldap_prefix'] = "uid=";
$config['auth_ldap_binduser'] = 'guccitown';
$config['auth_ldap_bindpassword'] = 'MYBINDPASSWD';
$config['auth_ldap_server'] = 'ldaps://ldap.jumpcloud.com';
$config['auth_ldap_suffix'] = ',ou=Users,o=MYJUMPCLOUDID,dc=jumpcloud,dc=com';
$config['auth_ldap_groupbase'] = 'ou=Users,o=MYJUMPCLOUDID,dc=jumpcloud,dc=com';
unset($config['auth_ldap_groups']);
unset($config['auth_ldap_group']);
$config['auth_ldap_groups']['LibreNMS']['level'] = 10;
$config['auth_ldap_group'] = 'cn=LibreNMS,ou=Users,o=MYJUMPCLOUDID,dc=jumpcloud,dc=com';
#$config['auth_ldap_debug'] = true;
When I run ./script/auth_test.php -l I get the following output:
[root@testbed librenms]# ./scripts/auth_test.php -l
Authentication Method: ldap
Users: (0), guccitown (5001)
Total users: 2
When I run ./scripts/auth_test.php -u guccitown with a known password I get the following output:
[root@testbed librenms]# ./scripts/auth_test.php -u guccitown
Password:
Authenticate user guccitown:
Error: LibreNMS\Exceptions\AuthenticationException thrown!
No such attribute
When I run ./scripts/auth_test.php -u guccitown with a known wrong password I get the following output:
Password:
Invalid credentials
Here is the config.php that generates the No such object error
$config['auth_ldap_groupbase'] = 'cn=LibreNMS,ou=Users,o=MYJUMPCLOUDID,dc=jumpcloud,dc=com';
Total users: 2
Password:
No such object
Password:
Invalid credentials
If I perform an ldapsearch on my JumpCloud instance I receive the following output:
[root@testbed librenms]# ldapsearch -H ldaps://ldap.jumpcloud.com:636 -x -b "ou=Users,o=MYJUMPCLOUDID,dc=jumpcloud,dc=com" -D "uid=guccitown,ou=Users,o=MYJUMPCLOUDID,dc=jumpcloud,dc=com" -W "(objectClass=inetOrgPerson)"
Enter LDAP Password:
# extended LDIF
# LDAPv3
# base <ou=Users,o=MYJUMPCLOUDID,dc=jumpcloud,dc=com> with scope subtree
# filter: (objectClass=inetOrgPerson)
# requesting: ALL
# guccitown, Users, MYJUMPCLOUDID, jumpcloud.com
dn: uid=guccitown,ou=Users,o=MYJUMPCLOUDID,dc=jumpcloud,dc=com
loginShell: /bin/bash
homeDirectory: /home/guccitown
givenName: Gucci
gidNumber: 5001
uid: guccitown
uidNumber: 5001
mail: [email protected]
sn: Town
cn: Gucci Town
displayName: Gucci Town
objectClass: top
objectClass: person
objectClass: organizationalPerson
objectClass: inetOrgPerson
objectClass: shadowAccount
objectClass: posixAccount
objectClass: jumpcloudUser
jcLdapAdmin: TRUE
userPassword:: OMMITED
memberOf: cn=LibreNMS,ou=Users,o=MYJUMPCLOUDID,dc=jumpcloud,dc=com
# search result
search: 2
result: 0 Success
# numResponses: 2
# numEntries: 1
