Leaflet.default_lng negative values
I’m unable to set negative values for leaflet.default_lat or leaflet.default_lng and am looking for a workaround. I’ve tried hardcoding in config.php, escaping “-”, specifying degrees + minutes format, and also specifying positive lat/long with orientation “W” for west or “S” for south.
librenms@nms:~$ lnms config:set leaflet.default_lng "-94.36"
  The "-9" option does not exist.
librenms@nms:~$ lnms config:set leaflet.default_lng "\-94.36"
"\\-94.36" is not an float
librenms@nms:~$ lnms config:set leaflet.default_lng '-94.36'
librenms@nms:~$ lnms config:set leaflet.default_lng '94.36W'
"94.36W" is not an float
librenms@nms:~$ lnms config:set leaflet.default_lng '94°21'
"94\u00b021" is not an float
librenms@nms:~$ lnms config:set leaflet.default_lat '38.65'
librenms@nms:~$ lnms config:set leaflet.default_lat '-38.65'
  The "-3" option does not exist.
librenms@nms:~$
librenms@nms:~$ ./validate.php
LibreNMS  | 25.2.0-11-g2cb8d9f04 (2025-02-24T14:25:44-07:00)
DB Schema | 2025_01_30_000121_add_ifindex_index_to_ports_table (315)
PHP       | 8.3.6
Python    | 3.12.3
Database  | MariaDB 10.11.8-MariaDB-0ubuntu0.24.04.1
SNMP      | 5.9.4.pre2
[OK]    Composer Version: 2.8.5
[OK]    Redis is functional
librenms@nms:~$
lnms config:set leaflet.default_lng -- -94.36
Awesome, thank you. Marked as solution.
