I am using firefox on windows 10 to access my webui. I have a color scheme built in my windows that I use to help make things stick out for me. One of those settings is a black background instead of white. Doing this has made it so I cannot see anything in the legend section because of the font color. I have seen in various posts about where to change the graph color in the config.php file. I was wondering if the same thing is available for the legend font colors. Or to change any instance where the font would be black to another color by changing the hex attribute associated with the black variable for font color.
disregard its the same – - I’m not sure why its not working. can you validate your install
to validate your install run ./validate.php and then pastebin your results
[FAIL] The poller has not run in the last 5 minutes, check the cron job
[WARN] Some devices have not been polled in the last 5 minutes.
Then a list of the devices.
For some reason after the reboot it broke the cron job. I have copied the file again both root and non root and it is not running when I check the cron status for each user.
In case someone comes here to find the answer, using Chrome and the High Contrast plugin works for me. I can’t change the colors, but I can see the Legend now.
