We have a Lenovo ThinkSystem DE4000F SAN (all-SSD drive array). When added via SNMPv3, it’s detected as “generic device” and doesn’t populate fan/temperature/etc data at all.
Output of ./validate.php:
LibreNMS | 24.12.0-45-g5beee764f (2025-01-07T17:14:18-06:00)
DB Schema | 2024_10_20_154356_create_qos_table (310)
PHP | 8.3.6
Python | 3.12.3
Database | MariaDB 10.11.8-MariaDB-0ubuntu0.24.04.1
RRDTool | 1.7.2
SNMP | 5.9.4.pre2
[OK] Composer Version: 2.8.4
Done ./validate.php
Can you offer any guidance on the bulkwalk command? I’ve used it before successfully with other devices but the “no response” output is puzzling when the lnms device:poll works as expected.
You can then build the snmpwalk command out of it. The interesting ones are : '-v2c' '-c' 'mysecretcommunity' 'udp:192.168.100.2:161'
which gives this snmpwalk command when you combine them with the -OUneb: snmpwalk '-v2c' '-c' 'mysecretcommunity' 'udp:192.168.100.2:161' -OUneb. | ./pbin.sh
