Sometime over the weekend, some update occurred that completely borked Libre.
In this case, running the validation script yields the following:
LibreNMS | 1.41-24-gad6ec7f
DB Schema | ?
PHP | 7.0.28-0ubuntu0.16.04.1
MySQL | ?
RRDTool | 1.5.5
SNMP | NET-SNMP 5.7.3
[FAIL] Missing dependencies! [FIX] ./scripts/composer_wrapper.php install --no-dev
symfony/dotenv
symfony/polyfill-ctype
myclabs/deep-copy
wpb/string-blade-compiler
[FAIL] Outdated dependencies [FIX] ./scripts/composer_wrapper.php install --no-dev
amenadiel/jpgraph
dapphp/radius
easybook/geshi
guzzlehttp/guzzle
influxdb/influxdb-php
symfony/polyfill-mbstring
symfony/var-dumper
symfony/debug
symfony/console
psy/psysh
and 14 more...
[OK] Composer Version: 1.6.5
[FIX] composer install --no-dev
Dependencies:
symfony/dotenv
myclabs/deep-copy
Needless to say, something has gone horribly wrong. I ran the suggested fixes…
> LibreNMS\ComposerHelper::preInstall
Package operations: 4 installs, 24 updates, 0 removals
- Installing symfony/dotenv (v3.4.12): Downloading (100%)
- Updating amenadiel/jpgraph (3.6.14 => 3.6.20): Downloading (100%)
- Updating dapphp/radius (2.5.2 => 2.5.4): Downloading (100%)
- Updating easybook/geshi (v1.0.8.18 => v1.0.8.19): Downloading (100%)
- Updating guzzlehttp/guzzle (6.3.2 => 6.3.3): Downloading (100%)
- Updating influxdb/influxdb-php (1.14.5 => 1.14.7): Downloading (100%)
- Updating symfony/polyfill-mbstring (v1.7.0 => v1.8.0): Downloading (100%)
- Updating symfony/var-dumper (v3.4.8 => v3.4.12): Downloading (100%)
- Updating symfony/debug (v3.4.8 => v3.4.12): Downloading (100%)
- Updating symfony/console (v3.4.8 => v3.4.12): Downloading (100%)
- Updating psy/psysh (v0.8.18 => v0.9.6): Downloading (100%)
- Updating vlucas/phpdotenv (v2.4.0 => v2.5.0): Downloading (100%)
- Updating symfony/css-selector (v3.4.8 => v3.4.12): Downloading (100%)
- Updating symfony/process (v3.4.8 => v3.4.12): Downloading (100%)
- Installing symfony/polyfill-ctype (v1.8.0): Downloading (100%)
- Updating paragonie/random_compat (v2.0.12 => v2.0.17): Downloading (100%)
- Updating symfony/polyfill-php70 (v1.7.0 => v1.8.0): Downloading (100%)
- Updating symfony/http-foundation (v3.4.8 => v3.4.12): Downloading (100%)
- Updating symfony/event-dispatcher (v3.4.8 => v3.4.12): Loading from cache
- Updating symfony/http-kernel (v3.4.8 => v3.4.12): Downloading (100%)
- Updating symfony/finder (v3.4.8 => v3.4.12): Downloading (100%)
- Updating nesbot/carbon (1.25.0 => 1.32.0): Downloading (100%)
- Updating league/flysystem (1.0.44 => 1.0.45): Downloading (100%)
- Updating laravel/tinker (v1.0.5 => v1.0.7): Downloading (100%)
- Updating symfony/yaml (v2.8.38 => v2.8.42): Downloading (100%)
- Installing myclabs/deep-copy (1.7.0): Downloading (100%)
- Installing wpb/string-blade-compiler (3.4.x-dev 30c974a): Cloning 30c974a305 from cache
- Updating oriceon/toastr-5-laravel dev-master (4ce3779 => 8a03502): Checking out 8a03502cc7
Generating autoload files
> LibreNMS\ComposerHelper::postInstall
> Illuminate\Foundation\ComposerScripts::postInstall
> php artisan optimize
Generating optimized class loader
The compiled services file has been removed.
root@thn-nms1:/opt/librenms# composer install --no-dev
Nothing to install or update
And everything was fine again.
The question is why does this keep happening? When an update is done, why is there a manual process to fix everything it’s broken? From an ongoing support/maintenance perspective, this doesn’t seem like a very good support model for an organization…where things keep breaking all the time.
